Can both inputs (RCS Unbalanced) and (TRS Balanced) be used at the same time?
For example: Can I run my computer into the RCA inputs and run my TV into the TRS ports, provided I use the correct cable/converter? Frank |
Welcome to the Forum!
Per the manual, it's not recommended (see below) but it's possible. However, you'll more than likely need something to control the levels independently between your two sources. Eris 3.5 User Manual Line-level Inputs. The Eris active speaker provides a choice of two pairs of inputs on the rear-panel: left and right balanced ¼” TRS and left and right unbalanced RCA. These inputs accept a line-level signal from an audio source and feed that signal to each monitor’s power amplifier. These inputs are provided to enable flexible connectivity, not for connecting multiple sources to your speakers simultaneously.
Download the SO 6 PDF MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) Subject 2) Description 3) Country 4) Product 5) OS 6) Audio Software Windows 11 Pro 64-bit (23H2), Studio One 6.6.1 Professional | Notion 6.8.2 | Universal Control v4.3.1.100005 Intel NUC 13 (Intel i5-1340P, Intel Iris Xe Graphics, 32GB RAM, 2TB SSD, Revelator, SIII 32 |
