Hi all,
This might be obvious for some. I need to assign a button to a VST paramater, and not a knob. For example an ON/OFF switch within a VST instrument or effect. I cannot find any way to do this. It looks like I can only assign those buttons to Studio One commands. What am I missing? Thank you |
Does this help?
Thank you for the answers.
No this does not really help because I knew I could assign commands on these buttons. What I am after is the ability to assign instrument features/buttons/toggles to these user buttons. I am surprised we can only use knobs. Surely we can assign things that can act as switches, right? |
I am not sure I understand how you phrased it.
But basically my problem is that so far I can only assign KNOBS to certain parameters of VST instruments. Some instruments (in fact many instruments) have buttons, or switches. Basically things you activate or deactivate by a simple click. Like an ON/OFF type of thing. I want to assign Atom SQ buttons to these, I thought I could do it with user buttons but it seems I cannot. But i must have missed something. Thank you |
No, you are right. As it seems that if you do not create an additional "mixer control" for the SQ, I cannot change the knobs to buttons.
Here is what I just did, sorry if this doesn't make sense, but it's working here: -Open options/external devices/"add" new mixer control. Assign the "receive from" to the SQ, name it something like "My basic SQ control" or whatever. Don't worry about the warning, just click ok/yes, whatever it is. -Then, in the control link of Studio One, get the window open for that new mixer control (double click? Sometimes I feel it's fiddly) -Go to one of the "user" options under user on the SQ controller. They'll say "not assigned" It's 5-8 on my unit as far as the option you have with the pages. -On that "user" page you are on, there will be nothing on that S1 display. Click "midi learn" and select the button on the SQ you want to assign. -You'll see a knob, BUT, you can change that. Where it now says "CC" and a number, click on that with the mouse and you have more options Select the button "press/release", unclick "midi learn" and then you can do what you normally do with assigning a controller.......WHEW! What a mess! EDIT! I guess you need "press/release" for it to toggle on and off. I'm not sure what "on/off" is for.......MUCH research needed. My my, I'm trying my best, not sure if anyone can follow |
Wow thank you, it does indeed work in some way.
I did what you suggested. I now have an additional device called "trigger buttons". I only used the page number 5 and created 6 on/off buttons with midi Learn. I then assigned them to certain buttons on Serato Sample (3rd party vst) and it worked, even after I shifted the control back to ATOM SQ ! So the buttons definitely work now, the way I wanted! However, for some reason, S1 does not remember the assignments, the next time I open a song and the same VST. My 6 buttons are in the device, but I need to assign them again (with the little left arrow) to the right paramater. It is not perfect but a hell of a progress! Thank you! (I still do not understand why there is not a better way to assign those buttons) |
Good work reggie
guillaumerivalle wroteHowever, for some reason, S1 does not remember the assignments, the next time I open a song and the same VST. My 6 buttons are in the device, but I need to assign them again (with the little left arrow) to the right paramater. After making the assignments try saving a preset in/for the plugin itself. Perhaps the preset will store the assignments way AmpliTube does. |
