The measure number goes from 78 to 85 instead of proceeding normally. Can this be corrected?
by michaelmyers1 on Sun May 05, 2024 4:41 pm
What version are you using? Notion 6 or Mobile?
macOS Sonoma 14.4
JBL LSR310S subwoofer
http://www.tensivity.com
by damoclessisyphus on Sun May 05, 2024 11:05 pm
I’m using Notion6.
by michaelmyers1 on Sun May 12, 2024 9:36 pm
No way that I know of that this could happen in Notion 6. Maybe there's a cut in the score?
macOS Sonoma 14.4
by damoclessisyphus on Wed May 15, 2024 5:07 pm
Even if there is a cut in the score, the measure numbers should still be correct. This has happened before.
by michaelmyers1 on Wed May 15, 2024 10:39 pm
I'd suggest creating a support ticket.
macOS Sonoma 14.4
by damoclessisyphus on Wed May 15, 2024 10:57 pm
Thanks for your suggestion. I tried it.
by damoclessisyphus on Thu May 16, 2024 11:55 pm
Support Ticket says:
①Set the view mode to either page below or page beside.
②Go to "Score" > "Full Score Options" > "Layout" > "Bar Numbers" and set it to "Every Bar".
③Double-click the bar before where you want to add a gap and enter the desired bar number value.
by michaelmyers1 on Fri May 17, 2024 5:05 pm
Thanks for posting! Always something new to learn with Notion! I didn't think it was possible to renumber measures.
macOS Sonoma 14.4
by damoclessisyphus on Fri May 17, 2024 7:19 pm
I also didn't think it was possible. Thanks for your advice.
