I just created a support request for parts, and asked about instructions for opening it as well. But has anybody here opened one up? It may just be "remove all the screws" and it opens up, but I'd rather leverage other's knowledge first.
Thanks in advance!
Studio One Pro 6; MOTU 828es / Helix LT; Intel B365 / i5-9700 / 16 GB; Windows 11 Pro;
Ex-Sonar user; Singer/Songwriter My record: https://rwaproject.bandcamp.com/album/thats-true |
Following up on this for those who are interested.
I contacted PreSonus support to find about parts and was sent to Fender, who ultimately sent me to a service center. I was not interested in going that route (effort, calendar-time, expense). So I opened it up, found the part, and replaced it myself. To open it up: 1. Take off the rubber feet. 2. Remove the 4 screws from under the feet. 3. Remove the forward 2 screws in the center (with the rear of the unit facing away from you). 4. Do not remove the other 2 screws. If you do, it isn't a big deal, but it slightly complicates re-assembly. 5. Remove the 3-screws on each side. 6. Do not remove any of the screws on the rear panel. The part I needed was for the little blue switches, not the back-lit source buttons. Those parts are titled "Antrader 30 Pcs Micro Push Button Switch, 6 Pin DPDT Self-Locking Power On/Off Latching Switches 8 x 8mm" on Amazon. Now it works perfectly and was well worth the minimal amount of effort!
