I am silly but I cannot find a way to switch the language to English.
If you are on iOS, then Settings > Scroll Down > Notion > Language If you are on Android, Language menu is available on App Menu. Thanks ! Sinan
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany --------------------------------------------------------------- iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD MacBook Air M2, 8GB RAM, 500 GB Flash SSD Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM iPad Pro 12.9 (5th Generation) RME Fireface UCX Official Artist of Kemper Profiler, EMG Pickups, GHS Strings Spotify: https://open.spotify.com/artist/5bAM9... http://sinancemeroglu.com http://youtube.com/sinancemeroglu |
thanks for your answer !!!!
strangely I cannot see anything that looks like settings. I’m in French originally so I see options I go to options menu .. I would include a screen capture, but I don’t know how to capture a menu in iOS it just gives me the screen without the menu. on the main screen, I go to the three dots and nothing looks like what I would like to have to switch language. If I select a file partition, I get options, and nothing is displayed about the language. I would rather use the English version since there are more examples names makes more sense in English than in French.. Is it on the start up screen ? or on a selected partition?? |
* you should go to iOS settings (cog wheel) * scroll down on the left column and find Notion * There you will see the language settings After that, Notion will restrart and change the language by itself. Thank you. Sinan
Sinan C. Eroglu
