Hi
Two questions: 1. Can I print out specified staff groups (strings or vocal choir or percussion group) separately. 2. How to delete multiple bars. If you mark several bars and then delete them, only one bar will be deleted. Is there a trick here. HPM |
1. Yes. Open your score > Export Score > Mode > Parts. That will export your parts as PDF file. Then you can print it out. 2. Select the bars that you want to delete > context menu > Edit > Delete measures. That will delete all the selected measures.
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany --------------------------------------------------------------- iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD MacBook Air M2, 8GB RAM, 500 GB Flash SSD Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM iPad Pro 12.9 (5th Generation) RME Fireface UCX Official Artist of Kemper Profiler, EMG Pickups, GHS Strings Spotify: https://open.spotify.com/artist/5bAM9... http://sinancemeroglu.com http://youtube.com/sinancemeroglu |
Thanks for the reply.
1. I already know that. My question was whether you can export a group of instruments from the entire score (Voc1, Voc2, soprano, alto, tenor or Vl1, Vl2, viol, cel). At the moment this can only be done very laboriously via the score by hiding all the instruments you don't want, changing the paper format,... 2. If you mark several bars and then select delete, only the last of the marked bars will be deleted. HPM |
