I've been trying to find a way to assign different mixes to the two headphone outputs on my 1824c. I thought that universal control's capacity as a mixer would make this easy, but I cannot find a way to do it. Apologies if this has a simple solution and I'm just too ignorant to find it!
Thanks in advance |
Welcome to the Forum!
Please update your signature (see link and example in mine) with your system specs as this information helps in responding to your questions. Are you using it with or without a DAW? Are your outputs configured for 1&2 (Headphone 1) and 3&4 (Headphone 2)?
Signature updated, thanks! Using w/ DAW, and as far as I know the config is the way it came out of the box. I haven't adjusted anything. I'm not at that computer right now, but I'll take a look in UC when I'm at my main desk.
If I'm understanding the images correctly (assuming default config), I can just press the mix 3/4 button, adjust faders, and then headphone 2 will hear that mix? Thanks so much for the help! |
I don't have an 1824c to test this but that's how it should work per the manual.
