I'm trying to route different sends in Ableton live to different outputs on Presonus Studio 1824c for some reason the right channel is always half of the left channel. I'm only using mono tracks in Ableton Live and I'm using a TRS cable so I'm assuming you can send two channels from one send? Any ideas?
Hi and welcome to this forum
Your post is slightly confusing because it’s mixing hardware and software sends. With exception of the headphone outputs all jack connections on the 1824c are mono. You can use them in pairs for stereo. TRS cables between balanced outputs and balanced inputs don’t make single outputs stereo but it greatly reduces noise picked up from the (long) cables. Sending signals from Ableton to the interface is in the software. Check the panning in Ableton and in the 1824c’s DSP mixer. With all panning set to center left and right outputs should be equally loud. Hope that helps |
