Hi everyone!
I wasn't able to find the frequency at which the sub output is set (Ceres 4.5BT) anywhere in the documentation. Does anybody know this (80 Hz, 100 Hz)?
If it's too high (ie 100 Hz) I will probably connect mine to a small sub I'm planning to buy (Fostex Submini) through the sub's crossover and set the freq. a bit lower (70-ish Hz) since it's not a very powerful sub and will probably be better to feed it only frequencies which Presonus are not able to produce well..
Cheers!
by matthewgorman on Fri Oct 21, 2016 7:24 am
I think, not 100%, but the sub output is full range, and you would set the LPF on the sub itself. I will try to confirm.
Matt
S1Pro V4
by matthewgorman on Fri Oct 21, 2016 9:17 am
Confirmed. No crossover in the speakers, LPF would be set on the sub. You would need the Eris 4.5 for an internal crossover
Matt
S1Pro V4
by ivanmilovanovic on Fri Oct 21, 2016 5:33 pm
Thanks for the info! :thumbup:
