We are not moving any data from the old forum. For any conversations you want to move, you can do this yourself.
The old PreSonus forum is available here, http://forumsarchive.presonus.com The old Notion forum is no longer online. If there are any stickies from the previous forum that you want replicated here, then you can send me a Private Message with a link to the post / thread and I'll see what I can do. If it's one or two messages then I'll see what I can do. If it's longer then, we suggest that you go to the old site and find the discussion you want to move over, copy the URL string and then post it as a link in the appropriate area on the new site as a continued conversation. |
Hi wolfgerb,
1st - So I verified what you and Tacman7 saw. Same condition, as Mute overwrites Touch mode. I also checked that this condition occurs right on the mute button itself on the mixer by switching it with both mouse, and controller. 2nd - I then tested a general on/off condition with Touch Mode by adding a Hammond B3 organ while switching the leslie rotary switch. Here, Latch mode worked as it should. Going back over switched automation in both on and off states did not overwrite unless I switched those positions by hand, mouse, or controller. Condition - As it looks, Mute while in touch mode does not work as expected (I'm using v 6.2). As you do, I think this should be addressed. 3rd test (to be done). I'd like to check an older version of Studio One such as version 2 or some older version today. Let's see if the mute condition using Touch mode works. This will tell us if it's always been this way, or something has changed. There is the possibility that Mute purposely overrides the Touch condition, but I can't say that's the case, but at least we'll have a better understanding of this. If so, then the manual should state this is the case. For all I don't know, it might.
