I've tried pulling up different new songs (using different s.o. templates and can't hear the pre-count or any metronome. I heard it earlier on song I started working on so can't figure out what I'm doing wrong. I check settings and all looks in order??
Newbie to this (oldbie to sequencing midi to roland mc50 & korg T3)
Using Mac osx 10.9.1 2.4 GHz Intel Core 2 Duo Memory: 4 GB 667 Controller: korg microstation (will add t3 and others later) Sound sources: Korg nx5r module & microstation Mixer TOA rack mount stereo outs into audiobox 22vsl audiobox: midi out of micro station into it's in, out of audio box into nx5r (will try "router" type function of my TOA mixer later to be able to send to other synths more easily |
Hey Bodacious
There are a couple of places to check. Hope this helps Ch33rs Saga
Studio One v2.x 3.x 4.x-
Windows 10 Ultimate 64Bit AMD Ryzen (3.4Ghz) and 32gigs RAM Graphic: Radeon 5700XT To add your software and hardware specs to your signature to make it easier for us to help you, click HERE. |
Thanx! i'll go check the upper one now. I already messed with the two on the bottom.
Darn, still can't hear it. I checked the mixer, upper right selection (was already selected) tried clicking it on/off, made no difference.
Learned how to record video screenshot (no sound yet), I'll upload to show what I was clicking. I'll mess with this more asap
Thanx, already shut that puter (program) down, will check tomorrow when I wake up! I think I already tried that. Tried every option shown there. I don't even hear or see a precount. It just starts recording the moment I hit record. ? hmm, maybe that's it. Maybe there is another setting/section on pre-count that i don't have checked (so even though metronome is set to do it's thing, the "thing" ain't happening!?).
ah HA! right around the 4min mark he starts talking about a separate pre-roll thing I need to click! I bet that's the problem. Can't wait to wake up and try it!!
Thanx everybody. All figured out! It was cause I didn't have the little actual pre-count button engaged. Little thumbtack looking thing just to left of the word metronome. Click it and when engaged it shows red (at least on my factory default 2.0).
So I must not have tried every setting in the met. setup, since I should've heard it if I took off the "pre count only" setting. Cause if that was unchecked, the pre count button wouldn't need to be engaged to hear the met. during recording from the actual recording start. I'll test right now. YEP! Duhl! Thanx again all!!!!! Now onto the 12,345 other things I'm gonna probably stumble over
jeffjameson wroteGot the exact same problem and cant't figure out whats going wrong... :') There could be multiple things at play. Please describe your system and what the problem is. |
S1 looks so old here/ ha
bodacious wroteDarn, still can't hear it. I checked the mixer, upper right selection (was already selected) tried clicking it on/off, made no difference. |
Users browsing this forum: johndoe313 and 4 guests
