I don't remember this being a problem before in older versions of Studio One, but maybe there's some setting I accidentally clicked.
Let's say I have an instance of Impact XT open and I have a drum part written as a MIDI part (not a pattern). Okay, I've recorded a kick and a snare in one go-through, cool. Now I want to record a hi-hat part over this same part, so I press record and do it again. But instead of simply adding the hi-hat part into the existing MIDI, it creates its own separate MIDI track and lays it on top. So now if I want to edit the kick, snare and hat I have to somehow switch back and forth between parts.
Why does this happen?
Windows 10 64-bit, 16GB RAM, AMD Ryzen R7 1700 3GHz, Radeon RX 480, Focusrite Scarlett 18i20 Gen 2, Studio One 4 Pro
by Tacman7 on Tue Jan 14, 2020 9:46 am
From new manual pg 53
Record Mode Options
Replace and Overdub
When in the Replace recording mode, recording over any existing Instrument Part results in the new material being recorded to a new Event, which replaces that portion of the original Event. While recording, you do not hear the previously recorded Event playing back, as the purpose of this mode is to replace the existing material.
When Replace is disabled, you are in Overdub recording mode. In this mode, recording over any existing Instrument Part results in the newly recorded material being overdubbed, or added to, the existing material. While recording, you hear the previously recorded Event playing, along with the material currently being recorded, assuming that you are monitoring the Instrument Track.
https://www.pro-tools-expert.com/studio ... cord-panel
Studio OnePro5.1 64bit Melodyne Studio
Kitchen Computer
Win10 Ryzen 5 3600 - Radeon RX 590 - 16GB DDR4 3000MHz - 512GB SSD interface: Motu M2
by codyhazelle on Tue Jan 14, 2020 4:30 pm
Tacman7 wroteFrom new manual pg 53
Record Mode Options
Replace and Overdub
that's it thank you!
Users browsing this forum: kisnou and 35 guests
