48 postsPage 1 of 3
1, 2, 3
Dear Studio One community,
we just updated with some little fixes.
Here the official thread: viewtopic.php?f=151&t=36304
Happy discussion!
Ari
by leosutherland on Tue Sep 17, 2019 11:49 am
Good grief! Already? :shock:
Thanks for all the hard work, guys! :+1
Btw - FIRST!
...said Halo
Studio One Pro v4.6.2
Serum, Diva, Repro, Synthmaster, Massive (+X), Syntronik Bully, MTron Pro, Kontakt/Reaktor, Xpand!2+AIEP3, PPG Wave 3.V, KLC, Generate, Battery 4, CA2600
Reference 4, Reverberate Core
3XS SQ170 Music Studio PC
Windows 10 x64 (1903)
i7 8700 Hexcore 3.2GHz, 16GB DDR4-2666, 1TB 970 EVO M.2 NVMe SSD + 1TB SATA HD
Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM
MSI GE62VR 7RF Apache Pro
Intel Core i7 7700HQ 2.8GHz, 16GB, 500GB 970 EVO M.2 NVMe SSD + 1TB 860 SATA III SSD
Beyerdynamic DT990 Pros, JBL 305P II speakers
by Quietly on Wed Sep 18, 2019 11:34 am
Thanks for yet another update. However since doing so I am getting a Midi playback problem as in a long note is playing back as a short one. I understand this is an old chestnut and can confirm that when I move the note up one semitone underneath is a short midi note. This has only happened since this update so any help would be appreciated.
In the meantime I will check how I can re-install the previous version.
Best,
Gerry
Just installed 4.5.3 and the problems remains. Maybe the update was just a coincidence but in either case I am now recording double notes, the played long one and underneath a short one is being added.
People who can't dance always blame the band.
https://soundcloud.com/gerry-cooper-855281238
Studio One 5 Pro. Windows 10 64 Bit 4 GB Intel 2 Quad Q 9950 @ 2.83 GHz . Fluid Audio SRI-2, NI Komplete Kontrol S61, NI Komplete 12 Ultimate, Izotope Ozone 5 and 8. Yamaha HS 80 Monitors.
by Trucky on Wed Sep 18, 2019 11:48 am
Quietly wroteThanks for yet another update. However since doing so I am getting a Midi playback problem as in a long note is playing back as a short one. I understand this is an old chestnut and can confirm that when I move the note up one semitone underneath is a short midi note. This has only happened since this update so any help would be appreciated.
Best,
Gerry
I'm not having this problem with MIDI notes with the 4.5.4 release. Does it happen for you in a newly created song?
To revert back to the previous version, log in to your My.PreSonus account and choose the following:
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account.
Windows 10 Pro 64-bit (20H2), Studio One 5.1.1 Pro | Notion 6.8 | Universal Control v3.4.0.61835
StudioLive Series III 32 v2.4.17466
by Quietly on Wed Sep 18, 2019 11:50 am
Thanks Trucky I found that but as above problem remains.
by Quietly on Wed Sep 18, 2019 12:02 pm
Its not a new song and I have previously recorded midi on it with no problems. I just wanted to add a midi instrument track today and this problem arose. Never ever happened before so I wrongly assumed the update was the problem but can confirm it isn't. Nothing else has changed on my PC and this is not happening in my other DAW's, that I no longer use.
by Trucky on Wed Sep 18, 2019 12:17 pm
@Quietly
Your specs show the NI Komplete Kontrol S61. Is this the device you're using for creating MIDI notes? What MIDI device did you add and setup for this in Studio One?
by Quietly on Wed Sep 18, 2019 12:21 pm
Trucky wrote@Quietly
Hi Trucky midi input was All Inputs which I assume is its default setting switched it to S61 and problem resolved. Still not sure why this is happening though as I am pretty sure I have always had it set on All Inputs. I could be going quietly crazy though. Thanks for your help.
by simonthompson on Wed Sep 18, 2019 1:38 pm
Sorry if in the wrong place, but is it possible to set different quantize settings on each bar? I.e. Could you have straight 16ths on bar 1 and 1/4 triplet on bar 2 or do you have to adjust every time?
by gregghart on Thu Sep 19, 2019 12:09 pm
Quantize is global. But, each part of Studio One has it's own quantize setting. In other words, the Step Sequencer / Event Editor can be set to 16th notes while the tracks can be set to 8th notes. But yeah, as far as I know, the quantize you have set for the window you are working in is global. If you want to quantize only a certain part of a song, you can highlight just that section, or you can split it and quantize that section.
Win10x64 (Eng), Studio One 3.5 / 4.1, 32GB DDR4 RAM, Intel i7 5820, nVidia 960, Focusrite 18i8. Native Instruments Komplete Kontrol S88, Native Instruments Komplete Kontrol S61, Presonus FaderPort 8.
https://gregghart.hearnow.com/
by Steve Carter on Fri Sep 20, 2019 8:57 pm
simonthompson wroteSorry if in the wrong place, but is it possible to set different quantize settings on each bar? I.e. Could you have straight 16ths on bar 1 and 1/4 triplet on bar 2 or do you have to adjust every time?
Is it definitely 'Quantise' or is it maybe 'Time signature' that you want to set for different bars?
by jangok on Wed Sep 25, 2019 2:07 am
After installing the latest version of S1, I have a problem exporting the song to the project. For example, I have several tracks in the song, some turned off (mute). When I export to the project, you can hear all the tracks - even the mutated ones.
It's troublesome because I have to try several times to make it work out and it will work one time ... but it lasts a long time.
Please, improve this version.
CPU: GenuineIntel Intel(R) Core(TM) i7-2640M CPU @ 2.80GHz, RAM: 8098 MB total, AMD Radeon 6600M and 6700M Series, Intel(R) HD Graphics 3000, Windows 10 Professional (x64), Scarlett 18i8 USB, Studio One 3 Pro, Progression, NI Kontakt 5, Music Lab Real Guitar 3.1, iLok, Waves, Toontrack Music - EZdrummer 2, Melodyne,
by PreAl on Wed Sep 25, 2019 4:24 am
jangok wroteAfter installing the latest version of S1, I have a problem exporting the song to the project. For example, I have several tracks in the song, some turned off (mute). When I export to the project, you can hear all the tracks - even the mutated ones.
Are you saying this is a new issue?
Studio One Pro 5, Faderport Classic (1.45), Atom Pad, Atom SQ, Presonus Studio 26c, Focusrite Saffire Pro 40, Maschine Studio, Octapad SPD-30, Roland A300, Windows 10 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Intel i9 9900K, 32GB RAM,
EVGA Geforce 1070 (Nvidia drivers).
by AriAhrendt on Wed Sep 25, 2019 6:41 am
I can not see any current issue with song adding to new project.
I guess he missed the function for updating the master file. So an already existing file is used.
If there really is a new issue, please make a new ticket with steps to reproduce.
Thanks a lot!
Ari
by frank.crow on Wed Sep 25, 2019 10:19 am
I also have not been able to export to the project page. I assumed that it was an isolated incident but now I’m not so sure. I have been using S1 since version 2 so I’d like to believe I’m pretty familiar with the process. This is definitely a new glitch.
I was considering abandoning S1 for Mastering and just use my Ozone 8 or T Racks Suite because I just don’t feel like fighting with the program as I have also lost the ability to export to SoundCloud.
Mac Mini (Late 2014)
Memory: 16 GB
Presonus. Studio One Pro V5
Presonus Quantum
Line 6. BassPOD XT Pro
Hardware DBX 160a
Hardware DBX 160XT
Art Pro Pro VLA II
WA76 1176 (clone)
EQP-KT Pultec (clone)
Softube. Console 1 MKII
Presonus. FaderPort & Faderport 8
"God's grace" :D
by lisarowe on Wed Sep 25, 2019 2:11 pm
Hi.
I'm having a problem since updating most recently.
I cannot select a midi event in the track view.
In this case, I am trying to alt drag an event onto another instrument track to have a duplicate.
I cannot select the event to preposition it in the track.
I can kind of select it by mousing across it. It won't copy and paste, but it will duplicate if I hit D.
Everything duplicates when I 'duplicate track complete' but I still cannot select any of the events.
I can edit everything in the edit window.
Nothing else has changed on my system.
Anyone else? Should I submit a support ticket?
Thanks.
Dell Laptop, Intel Quad Core i7, 16GB RAM, Windows 10 64-bit, Studio One Pro 5.1
Rode AI-1
Audiobox 44VSL
AKAI 25 and Keystep 32 midi controllers
8-)
by IanM5 on Wed Sep 25, 2019 2:32 pm
lisarowe wroteHi.
Thanks.
I reckon you might be in the combi tool mode. That's where the cursor switches to the arrow tool if you are in the lower half of the event and the range selection tool if you are in the upper half of the event. It confused the heck out of me the first time I accidentally did it but now I love the tool. It's a real time saver. The combi mode is selected with the square bracket to the left of the arrow tool on the top toolbar.
Or it might not be that at all, in which case just ignore me!
Studio One Pro 4, Intel i5-8400 @ 2.8GHz, 32GB RAM, Windows 10 Pro 64-bit
Focusrite Scarlett 8i6 (3rd Gen), Novation Launchkey Mini Mk3, Akai MPK Mini MKII, Novation Remote 25 (ancient, but not as ancient as I am)
Guitars, Mics, Synths, Upright Piano (tuned circa 2005), £50 drum kit, Wife (with Cello and Cello skills)
by frank.crow on Wed Sep 25, 2019 4:40 pm
lisarowe wroteHi.
Thanks.
No way
Me too
Memory: 16 GB
Presonus Quantum
Hardware DBX 160a
Hardware DBX 160XT
Art Pro Pro VLA II
WA76 1176 (clone)
"God's grace" :D
by bradtanabe on Thu Sep 26, 2019 1:31 pm
Please help me!!!
how do i get rid of this empty space above the inserts tab? it is really weird. every time i try to snip it with snipping tool it goes away. i had to take a photo with my phone for you to see it.
thanks.
by lisarowe on Thu Sep 26, 2019 2:19 pm
frank.crow wrote
No way
Me too
I'm glad to hear this! I thought I was nuts for a day or two. I have since seen that after I closed S1 and later reopened one of the songs in question, everything worked just fine.
I am going to spend some time recreating the issue, I guess.
FWIW to other reply, Ian, I always have the multi/combi tool engaged, so the arrow should have automatically selected the event and an Alt drag would have done the right thing without issue. It's in my muscle memory pretty deeply. Thanks, though.
Rode AI-1
Audiobox 44VSL
8-)
48 postsPage 1 of 3
1, 2, 3
Users browsing this forum: slylarock and 15 guests
