this is my last mix on this one, as i wrap up final mixes on 8 new tunes for a new album.
looking for how this translates on your playback, particularly, if the kick and bass guitar are coming across good. tnx. https://www.dropbox.com/s/i7up1pyhoqok8 ... q.wav?dl=0 |
Hmm, I think it's fine in the bass areas.
![]() Mixing and Mastering is subjective but to me the sparkle of the cymbals, crunch of the guitars and snap of the snare all sound dull. ![]() I compared your song here to some of my stuff, Joe Satriani and Shinedown.
If you haven't already done so...
Please add your Signature & Gear Spec's located in your profile Here. ASUS G75VX, i7 3820QM; 16GB; 2 Samsung 840 SSD's; NVIDIA GTX 670MX; Win 8.1. S1 Pro v4.5.2; EZD2 2.1.7. Behringer UMC404HD USB A/I. Synths: Alchemy, Air Tech Music Suite. Melodyne Studio 4.2. Ozone 5, (all 64bit). Akai MPK249. Six guitars. 2 Line 6 POD's & an E-bow. Rode NT1; Shure SM58. Faderport; KRK Rokit 8's; Dual 28" Monitors. -My Band: "2GUYZINABASEMENT" -Just Me |
hey thanks scotty...
you know, i had a bunch of high end on all that stuff you mention (i NEVER want a ME to add high end for crispiness, it should be right in the mix, always!) and i thought it sounded fatiguing, so i mellowed it out a bit. i suppose if you are only listening to one song at a time, it makes sense to make it bright, but i'm worried that in an album setting (that IS the intention of these 8 songs i've just finished) that it might wear the ears out, if it's on 'stun' on every tune. it would very easy to add a bit of high end, for sure, to the overheads, and the guitars in general... i'll play with that a bit. |
Kick and bass are OK.
Kick could be more pointed like up 1 db and then use HPF 35hz. Bass lows are good but low mids are a touch shy IMO. Like +2 1K (can't believe I wrote that). Cymbals and toms need to come up. Overall good mix. Have you ever run your mix thru Ozone to see what it would recommend? I just finished a mix and the only thing it told me was my 200hz needed +2. I was happy with that. Not to say to use it soley but just as another opinion. Your mids on the vocal seem a little boxy but that's not the right word and it's just a little that way. Lastly, what would it sound like with +1.5 at 120hz on the rhythm guitars to add fullness and body? That's all I got. Best of luck with your album!
Please add your specs to your SIGNATURE. Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 4.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, ELAC Sub, ATOM |
Sounds awesome
![]() ![]() Just for everyone's reference, I listened on my tiny Alesis 3 monitors, and my Audio Technica ATHM30-X headphones, and any mix sounds a lot different between those 2 things. It really sounded great when I listened both ways. I especially liked what you did with the vocals at 2:25 to2:37. That is so well done, as is the whole song and mix. P.S. Vocally, you're giving Bruce Dickinson a real run for the money! |
guys,
not a 're mix', but a quick EQ to see if i'm going in the right direction with the top end: https://www.dropbox.com/s/zuks1u56mkke6 ... 5.wav?dl=0 |
I opened both versions and listened to 5-10 second segments of each one (pretty close to A/B-ing) on my headphones.
The latest is definitely crisper in the top end to me. It sounds even a little better, momentarily. But for me, if I listened to it louder for more than a brief period, my ears would "adjust", or get fatigued... and that extra top end sheen would wear off. So, my "vote" is for the first one. As always, that's just me. Sounds great either way! |
Bbd wroteKick and bass are OK. hey bbd, thanks for the detailed listen. i'll tweak drums, that is pretty easy. knowing what to focus on, helps me hunt it down. i do not use Ozone, but i do use Har Bal. i think the boxy quality of the vocals is due to the fact that i ran the vox thru a tube preamp set on "Stun".......... LOL and again, i can tweak that to get rid of something around 450hz, carve out a bit of the box. i have a HPF on the guitars, starting abouit 80hz, but haven't boosted anything, i'll try playing with that too! |
sirmonkey wroteSounds awesome hey monkey, great to know it's translating between those two sets, that's about as good as i can get it for a big compromise for smaller systems. |
