If I try to insert a note so that it begins at the start of an event, it always opens the preceding event and inserts at the end of that.
I find I have to (when I remember) insert the note a little time into the event I'm working on, and then slide it back to the start. It's a real pain to have to do and real frustrating when I forget and I end up having Undo a note Anyone got any ideas?
...said Halo
Studio One Pro v4.6.2 / v5.5.2 / v6.5.2 Serum, Diva, Repro, Synthmaster, Syntronik Bully, MTron Pro, Kontakt 6/7, AIR synths, Cherry Audio synths, Battery 4, PPG Wave 3.V, Generate 3XS SQ170 Music Studio PC Windows 10 x64 (22H2) i7 8700 Hexcore 3.2GHz, 16GB, 2TB 970 EVO+ M.2 NVMe SSD + 1TB SATA HD Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM Beyerdynamic DT990 Pros, JBL 305P II speakers |
No takers at all?
Guys, if I'm asking a stupid question, apologies, but at least tell me I'm being thick!
...said Halo
I'm not having that issue, I have tried with snap to quantise set at 1/8th, and also with snap to events.
Both times it works without issue for me. Best Scott
Studio One Professional v6, Apple iMac Pro 14 core, 128gb memory, 4TB SSD. macOS Ventura, Main audio interface is RME Babyface Pro. Presonus 192, DP88 (not currently used), RC500, ADL600, Focusrite ISA430, TC4000 reverb, SPL Phonitor, Monitoring: Event Opal, IK Multimedia MTM Studio Monitors x 5, DMAX audio Super Cubes. HD800s mastering reference headphones. Sequential Prophet 12, Prophet 12 modules x4, E-MU 4XT Ultra, Roland Fantom 8, Korg Pa3x, Roland Fp7-F, MOTU midi express 128, Xkey air 37, Studiolive CS18, Atari STE with Notator plus loads of microphones and plugins etc
musicchamber wroteI'm not having that issue, I have tried with snap to quantise set at 1/8th, and also with snap to events. OK, thanks Scott. I'll have to do an investigation myself to see if there is a pattern of use, hopefully will report back in case anyone else is affected
...said Halo
vanhaze wroteWhich workflow do you use to create a Note ? With the Paint tool (I assume that is what I would call the Pen tool). Essentially, if I click right at the start of the event where I want to draw the note, it selects the previous event instead and the note gets drawn there instead (also moving the RH edge of the previous event to the right as I draw the note to the right). As I said at top, I can workaround by starting it a bit in from the event start, then dragging it back, but I find that really annoying - hey, that's me have to admit I didn't realise you can 2click the arrow tool - does that insert a note of the currently set length, or does that just start the drawing of the note so I can drag right to grow the note (sorry, NAD atm)
...said Halo
OK here we are at 4.5.2 - still cannot insert note right at start of event
Have raised a ticket, will report any developments
...said Halo
Try to make a video.
I still do not understand your problem! |
leosutherland wroteOK here we are at 4.5.2 - still cannot insert note right at start of event I have seen what you are describing. I was just dragging over the midi note when it didn’t place as I wanted. I will try to look at this again today. |
Win 10
S1 4.5.2 1. Open MIDI editor. 2. Set Quantize to 8th's (for this test) 3. Select Pen tool. 4. Click on Bar 2 Beat 1 to insert note. It is placed where I wanted it. No issue. What are you doing differently? Thanks. |
Bbd wroteWin 10 Working fine today for me as well at all quantize settings. I think what I was seeing was with a previous version, but I really couldn't say which one. Hopefully this issue works out for you. |
Bbd wroteWin 10 Is Bar 2 Beat 1 the very first beat in the event? - I can accurately (well, mostly) place a note anywhere within an Event, just not on beat 1 of the event (ie. on the leftmost edge of the event) - even if the Event is at Bar 45 Beat 1 for instance. By Midi editor, do you mean Piano Roll editor (just so we got the same window open )?
...said Halo
Music Editor.
Select your Instrument part in the Arranger. Press F2 to open the Music Editor. The same as double-clicking on the Part in the Arranger. |
OK cool, we're talking about the same place
So I have an Event selected (from the main window). I zoom right into the Editor (dragging down from the timeline) with the border of two Events in the centre. My Q is at 1/32 though I did also try 1/8 (the zooming in bit is irrelevant to the problem, as is the borderline being in the centre). Using the pen tool, I position it just on the RH edge of the borderline between the two events which is where I expect beat 1 of the event to be. When I click, the event to the left gets selected, and expanded and the note is place there at the end of the preceding event. I'm sorry, but there is no way I can explain it any clearer than that - a video would only show exactly what I am describing. Thanks for everyone's patience
...said Halo
Users browsing this forum: No registered users and 63 guests
