My FP8 was working fine in Studio One Pro 4.14 (Windows 8.1 Pro).
I upgraded my OS to (Windows 10 Pro) , then Installed the latest Univ. Control application, and updated the FP8 Firmware to ver. 3.1 , sadly it is not working now :(
The transport functions do not work, when I have a VST Inst. and loaded, and press the VI button, it does not light up. , when moving a fader on the FP8, it doesn't show up on the Controller panel in S1.
Oddly, the FP8 fader will react when changing the volume of the VST Inst. via it's GUI in S1, but not the other way around. So simply put it is not working properly.
Any suggestions to fix this issue ?
Thanks,
Muziksculp
by muziksculp on Tue May 07, 2019 7:54 pm
OK. Issue SOLVED !
I found out what was causing the problem.
I had the FP8 connected to a USB hub, I tried connecting the FP8 directly to my PC's USB Port, and all is working as it should now. I guess it didn't like the USB hub it was connected to.
Cheers,
Muziksculp
