190 postsPage 7 of 10
1 ... 4, 5, 6, 7, 8, 9, 10
Sostene wrote: "How do i make my own set of color to import into the script?
Just load the script as is. You can then colorize it differently, rename it, and save that. Put it in the same scripts folder for easy access. Save and Load any that you've named, right from the toolbar.
Nothing else to bother with.
New song "Our Time"
Visit my You Tube Channel
Latest albums on iTunes
by THECELTANDIR1 on Fri Jan 10, 2020 5:23 pm
I can get the color bar to come up and as long as I hi-lite the "E", I can change colors on the track segments with no problem. But when I disengage and try to color the channel, I get a script error.
by Lokeyfly on Fri Jan 10, 2020 6:04 pm
Read the very first comment from the user who was nice enough to create the Track color script.
Lawrence wrote: "Here's a toolbar add-on that allows you to create, store, import and export custom color sets of 40 colors using any RGB colors to color tracks or events."
The name of the post is Track Colors. Now I can't say for sure because I haven't tried to color channels which isn't a part of the script. Says nothing about that.
Feel free to color tracks, or events though.
New song "Our Time"
by THECELTANDIR1 on Fri Jan 10, 2020 6:42 pm
Perhaps I wasn't clear, but it will ONLY color the events.... but not the track. When I attempt to change the track color is when I get the error.
by Trucky on Sat Jan 11, 2020 1:43 pm
THECELTANDIR1 wrotePerhaps I wasn't clear, but it will ONLY color the events.... but not the track. When I attempt to change the track color is when I get the error.
What OS and Studio One versions are you on?
Windows 11 Pro 64-bit (23H2), Studio One 6.5.2 Professional | Notion 6.8.2 | Universal Control v4.2.0.96206
by THECELTANDIR1 on Tue Jan 14, 2020 10:25 am
Studio One Pro 3.5.6 Mac OS High Sierra 10.13.6
by Trucky on Tue Jan 14, 2020 11:19 am
Thanks! That explains it.
I tried it on my 3.5.6 version (works on my 4.6 version) and saw the same errors.
The developer for the Color toolbar designed it to work in Studio One 4 so features may or may not work in earlier versions of Studio One.
Please note that there are no plans for backwards compatibility.
by THECELTANDIR1 on Tue Jan 14, 2020 12:35 pm
Thanks Trucky!
by kozmyk on Sun Jan 19, 2020 10:15 am
I really like this toolbar package. Well done Lawrence.
Do you know if there is a way to Lock colours ?
I'm forever changing them by accident as I scroll wheel back anf forth; on the Mix page particularly.
My Ctrl+Z gets used more for Undiong unwanted colour changes than anything else ...
Firepod(FP10 firmware), Studio One v5.0.1 (Sphere), Melodyne 5 Studio, Ableton Lite, Bitwig, Mixers (Soundcraft,Behringer,Studiomaster) Remotes Android, Sensel Morph, Instruments Basses, Guitars, Keyboards, Banjo, Didj, Cowbell, Mics-Dozens
Win10 Home, Intel i7 3770K 4.2GHz, 32GB RAM, Gigabyte SKT-1155 Z77X-UD5H, Gigabyte GeForce GTX670 2GB
by Lokeyfly on Sun Jan 19, 2020 11:47 am
It's the gift that keeps on giving!
No way to lock colors as it is, unless you modify the script yourself. I wouldn't know those possibilities, due to time constraints. Lawrence has had numerous questions, requests, and thoughts for such color medications, but I like how he's kept it simple. What you see is what you get.
Suggestion. If you like how you set up some colors, just simply rename the file, and save it. You'd be locking the whole group, but it's still a way to keep what is there.
You could store and retrieve color names as necessary for the type of song, i.e. Rock, Soft, Trio Band, Orchestral, etc.....
Hope that helps.
Hey, the fact that you can control Z back, is a good thing. Now just hold tame that scroll wheel. ;)
New song "Our Time"
by kozmyk on Mon Jan 20, 2020 5:06 am
The lock colour facility wouldn't strictly have to be part of Lawrence's toolbar.
I posted the question here as it might be something that Lawrence might Know about.
Being a related function then, a small s[ace on Lawrence's toolbar might be a suitable place for a Colour Lock Button.
Perhaps I'll also post in Feature Requests and see who salutes it ...
by Lokeyfly on Mon Jan 20, 2020 7:08 am
Yeah, others do modify scripts, so it's out there. Little has changed with this, but nothing ventured, nothing gained, I guess. Good luck, as it sounds like it will be a good feature for you and some others.
New song "Our Time"
by kalebgebremedhin on Tue Feb 04, 2020 5:52 am
thanks for this color scheme it helps a lot
by BezowinZ on Tue Feb 04, 2020 3:21 pm
To spin off this, can someone (re)confirm if these colors are available for console channels? I currently have tracks, events and channels colored with the sub par options available and would like to keep with that theme.
I believe the answer when I asked a while back as no. But this script was mentioned in a Facebook group, so I asked there in case something had changed, and I was told yes.
Can someone confirm, please?
Studio One 5.5.2 Pro
3.6GHz 8-Core i9, 64GB RAM, iMac, OS 10.14.6
2.8GHz 4-Core i7, 16GB RAM, MBP, OS 12.6
Clarett 8Pre Thunderbolt
by Trucky on Tue Feb 04, 2020 3:51 pm
BezowinZ wroteI currently have tracks, events and channels colored with the sub par options available and would like to keep with that theme.
There's multiple color setting options in Studio One 4.6.1 that can impact the Color Tracks add-on. For me, when I click on a channel or track it updates both with my color choice. With the Event button enabled it only colors the event.
Can you post a screenshot describing your request regarding "track, event, channels colored with sub par options" and what color setting options you have enabled?
by BezowinZ on Tue Feb 04, 2020 5:45 pm
I think that answers my question. I was only saying I'm set up like you, so that changing colors for a track/channel changes it for the other. My events are also the color of the relative track/channel.
I thought someone said earlier in the thread that this script only applied to track colors. I must've misunderstood. I'll be downloading.
One more question. Is the color "strip" hide-able or is it permanently shown in the toolbar?
Thanks!
by Trucky on Tue Feb 04, 2020 11:24 pm
The icon is always there (once added to Scripts folder) in the menu but the color selection bar only shows when you click on the icon.
by kerryvance on Fri Feb 07, 2020 1:01 pm
I downloaded the file and placed it in the scripts folder. When I open Studio One (4.6 Professional), I have the colors icon and the dialog box opens but there are no colors in the small rectangles where the colors should be. Any help would be appreciated. Thanks.
by Trucky on Fri Feb 07, 2020 3:27 pm
What's your screen resolution? I'm not sure if the screenshot you posted is cropped but not all 8 groups of colors (5 per group) are being displayed.
If it's not a screen resolution issue, try loading the "Default Set" from the dropdown menu:
by kerryvance on Fri Feb 07, 2020 6:27 pm
My resolution is set for 1920 x 1200 (recommended) and yes, all 8 of the color groups are displayed. When I try loading the Default Set, nothing happens. (I tried uploading a larger jpg and got a dialog box telling me the maximum size had to be no more than 800 pixels wide and 600 pixels high). Thanks for such a quick response, Trucky.
Windows 10 (Home) - Dell XPS8930
Intel(R) Core i7-8700 CPU @ 3.20GHz / 6 cores / 16.0 GB ram
NVIDIA GeForce GTX1050 Ti
Presonus Studio One Professional 5.5.2
Focusrite Clarett 4PRE USB
Users browsing this forum: No registered users and 62 guests
