More or less all in the subject.
Being a modest musician, I use scores which could fit only on one page. But Notion seems to automatically reserve the upper part of the page for Title-Dates, etc.. which I don't need, not peforming, or even training with others.
Is there a way to have the beginning of the notes starting from the top of the pages, like 2 cm above or stg?
Thank you so much and Happy New Year.
Etienne
by michaelmyers1 on Sun Jan 06, 2019 1:51 pm
1. Delete all unwanted titles, composer etc by selecting them and using <delete> key (they can be added later if needed).
Then either:
1. Under <View> menu, select <Show Layout Handles> or use <command/ctrl L>
2. Grab the square to the left of the first staff and move it to the desired location.
OR (this is probably the easiest method):
1. Under <Score> menu, select <Full Score Options>
2. Under the <Page> tab, change the <Top, First Page> margin to your desired margin size.
iMac 27" 3.6 ghz I7 quad core 32 gb RAM Fusion Drive
macOS Mojave 10.14
ResidentAudio T2 Thunderbolt audio interface
JBL LSR310S subwoofer
Notion 6 + Studio One 4 Pro
http://www.tensivity.com
by etienneloyon on Sun Jan 06, 2019 2:01 pm
It doesn't seem I have the first option ("handles..."). Maybe it's a N6 option?
And I had tried to work out the margin, but sofar, no success.
I found a turnaround. Starting from the second page, creating a lot of empty staves. Ok for printing at least (I select only p2. ). Not so practical but well...
Thank you for your time), still.
by michaelmyers1 on Sun Jan 06, 2019 2:59 pm
Etienne, yes, sorry, Layout Handles were added in N6.
The page margin option should work though as well. It always worked in every version of Notion I worked with.
macOS Mojave 10.14
by etienneloyon on Mon Jan 07, 2019 1:24 am
AH ok,I was clicking at the wrong place (trying to enter value in upper margin) instead of notching
the lowest case.
Great sofware, indeed.
:D
