First of all I apologize if you are posting in the wrong area.
My question is in transforming the track to audio.
At the moment I do the process, I select everything correctly and soon after the finished process the new channel gets the volume in "0db" again. I wonder if this is normal or if there is any way to turn it into audio but without modifying the volume of the channel fader, as I would like it to continue on the same volume as I left.
Thanks.
Rivera.
by snb1 on Wed Jan 23, 2019 1:32 am
mikeanderson4 wroteFirst of all I apologize if you are posting in the wrong area.
Thanks.
Rivera.
If you want to keep the fader in the same position, you would have to turn Render Inserts off.
Studio One Pro 4.1.2 64 bit, Mac OS 10.12.6, Mac mini (Late 2012) 2.3GHz quad-core Intel Core i7 (Turbo Boost up to 3.3GHz) with 6MB L3 cache, Intel HD Graphics 4000, 16 GB ram, 240 GB OWC Extreme Pro 6G Solid State SATS Drive startup disk, 1 TB internal SATA Dive, (2x) 1 TB External Glyph Studio 7200RPM eSATA Drives, 500 GB External WD Drive
SkipNo Beet Productions
