Will there possibly be a driver update for the Firestudio Projekt/Mobile/Tube for MacOS Mojave?
Does anyone know, if it runs on Mojave with the current driver (UC 1.7.6)?
- Mac Mini 6.2, (2014), internal SSD+HD, 2,3 GHz Core i7 quad, 16 GB RAM, MacOS 10.14.6 Mojave with Presonus Firestudio Tube, Firestudio Project with Universal Control 1.7.6,
Presonus Faderport8, Atom, Bluetube DP, HP 4, Bluemax.....
- iMac 27" 3,4 GHz Core i5 quad, 1TB Fusion-Drive, 40 GB RAM, MacOS 10.15.5 Catalina with Presonus Studio26C
External harddiscs (3.5" - 7200 rpm) USB 3.0
Presonus Studio One Pro 4.6.1
Celemony Melodyne Studio 5.0
Softube Console1 MK II, Volume 2
by Trucky on Wed Oct 17, 2018 7:15 am
Windows 10 Pro 64-bit (1909), Studio One 4.6.1 Pro | Notion 6.5 | Universal Control v3.2.1.57677
StudioLive Series III 32 v2.3.16845
by MarkusHassold on Thu Oct 18, 2018 12:15 am
Thank you very much, Trucky! This is helpful indeed.
So now I only have to find out, if my FirestudioTube, which is running on the same driver (and which is used daisy chained to the Firestudio Project here on MacOS High Sierra without any issues) could be making problems.
by lancedixon on Tue Nov 06, 2018 4:07 am
FS-mobile not syncing on 10.11.1 here
Ozfrog
by klypeman on Tue Nov 06, 2018 5:26 pm
lancedixon wroteFS-mobile not syncing on 10.11.1 here
Have you tried to go to the UC and switch from Firestudio-Master to SPDIF and back ?
Have solved issues for me on two Projects daisy-chained.
Moderator
Windows 10 64bit Home, Mac Catalina, SO4.6.1 Pro, LUNA, Cubase 10.5 Pro, SLIII32, 24.4.2, 16.0.2 FW, Faderport 8, Atom, UA Apollo Twin TB/USB, Toontrack, NI Komplete 12, ++
by MarkusHassold on Fri Aug 23, 2019 2:30 am
Just to keep this updated. Mojave worked really well up to 10.14.4.
After updating the OS to 10.14.5 I had to reinstall UC because of occurring crackling. That did the trick. After updating to Mojave 10.14.6 it is crackling here and there - even after reinstalling UC.
So I think the Firestudio- interfaces are outdated soon, if there is no driver-update coming. What a pity this would be. They are still great and have great preamps.
by cristofe on Fri Aug 23, 2019 2:10 pm
Very few manufacturers support discontinued hardware forever. If you want to continue to use unsupported legacy hardware......get off the update train. I've got 2 Firestudio 26x26's and a MOTU 8Pre for a 24-trk recording rack. There's nothing wrong with the hardware. It cost me FAR less to simply build a legacy pc FOR the hardware than it would have cost me to buy all new interfaces.
Sure, I have other machines that run shiny new OS's for other reasons. But there's no need to "upgrade" my DAW. It works fine. It's not broke....and I'm not going to fix it until I have no other choice.
by MarkusHassold on Mon Oct 28, 2019 8:03 am
Installing under Catalina is impossible.
So instead of buying a control surface or new monitors a new interface has to be?
Really?
by cristofe on Sat Nov 02, 2019 12:13 pm
I've gotten e-mails from DOZENS of major companies including Roland warning Mac users NOT to update to Catalina. Apple is throwing the entire pro audio industry under the bus. They don't care about this small niche market. They are more concerned with their pc's playing nice with their iPhones and iPads. If you don't like it that you're gear doesn't work with newer Mac OS's it's APPLE'S fault. Complain to them.....or switch to Windows.
