31 postsPage 2 of 2
1, 2
Link Mode
Firstly it is explained in the manual. But I will also explain here. It is different in Faderport and Faderport 8/16.
Open a plugin on a track e.g. Pro EQ. Press Link button to light up. Hover your mouse over a parameter e.g. the frequency control for a particular band. The rotary encoder Pan/Parameter (Small Blue Knob top left) now controls that parameter in FP 8/16. In new Faderport the large Blue rotary encoder will do this.
Move your mouse now to another parameter and hover mouse directly over it. e.g. Gain of another band. Small Pan/Parameter Rotary knob now controls this parameter in FP 8/16 and large rotary encoder in new Faderport will do this.
Once you get used to this it is quite an amazing feature.
Shift+Link locks a parameter to the rotary knob.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 8 and 2018- Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V4.6.1 (Mac), Notion 6.5, Ableton Live 10 Suite, LaunchPad Pro
by Jemusic on Mon Mar 04, 2019 11:39 pm
The new Faderport is vastly superior to the classic model. Also it runs at USB 2 speeds now and will not slow your USB port down to USB 1 speed which is what Faderport classic will do. Not good if you have got an audio interface on the same port.
Also Faderport 8 is excellent in terms of knowing what tracks you are looking at. You just have to get used to it. Firstly it needs to be directly in front of you. Not to the left or right. Also you need to prop it up at the rear by about an inch or so. It is far easier to use and see the scribble strips.
Using the Bank button in conjunction with the Next Prev Buttons allows you to fly though large sessions with ease. Also some may not know this either. If in the software you whip down to channel 25 for example but Faderport is still showing you Channels 1-8 all you do is press the encoder button. Then Faderport 8/16 will jump right down to the selected channel in the software. Not only that the select light will be lit so you immediately know which channel to twiddle.
Faderport 8/16 is also better when you want to fine tune a whole bunch of tracks at once while you fine tune a mix. e.g. 8 drum tracks etc.
by pauldormer1 on Fri Mar 08, 2019 6:11 am
Jemusic wroteThe new Faderport is vastly superior to the classic model. Also it runs at USB 2 speeds now and will not slow your USB port down to USB 1 speed which is what Faderport classic will do. Not good if you have got an audio interface on the same port.
My interface is connected via Thunderbolt wouldn't want USB 2 slowing it down ;)
However I did some searching on this issue, and I think it might be an urban myth. Mostly I ran into people saying, Naaaah.. won't do that...
Not unless you've got a poorly designed hub (and it is hubs we're talking about here)
I might test the theory out later with a quick SSD read / write test.. with / without the FaderPort classic connected.
by Jemusic on Fri Mar 08, 2019 12:47 pm
If your audio interface is connected via thunderbolt then the USB ports won't be effected anyway. Also PreSonus put out the warning about the classic Faderport running at USB 1 speeds, not me. So for them to say it then there may be some truth in it.
Personally I have my Faderport 8 (and originally Classic) connected to a pair of USB ports which are fed via a separate set of outputs from the motherboard that were independent of other USB outputs anyway. So even with the Classic I never experienced any issues. I don't use it now and have FP8 connected to those same ports so it seems like they are on there own USB outputs and don't effect anything else. Nothing else is connected on those ports also.
by pauldormer1 on Sat Mar 09, 2019 2:18 am
Jemusic wroteIf your audio interface is connected via thunderbolt then the USB ports won't be effected anyway.
True but I have 7 or 8 other things connected to the hub!
Jemusic wroteAlso PreSonus put out the warning about the classic Faderport running at USB 1 speeds, not me. So for them to say it then there may be some truth in it.
Had a look for that but with no success. Where can I find the quote?
by Jemusic on Sat Mar 09, 2019 2:49 pm
It was on the site somewhere, but a while ago I think. I agree it seems to be no longer there.
All the new models work at USB 2 speeds now so there is no need for concern.
by reggie1979beatz on Sat Mar 09, 2019 7:19 pm
Jemusic wroteLink Mode
I see now, thanks.
Studio One 4.x, Win 10, I4770K (no OC), 16GB, RME Babyface Pro and tons of plugs.
by reggie1979beatz on Sat Mar 09, 2019 7:57 pm
Just as an added note, That "blue" knob is annoying with all the clicking. What would be cool (or maybe I'm missing something) is if you could have the fader be the one and hit the link off to go back to volume. It's WAY smoother.
by reggie1979beatz on Sun Mar 17, 2019 6:44 pm
Well, I sold mine. Not sure if I'll be getting the 8 but it was foolish for me to jump the gun. Good unit, worth the price for some things, but the 8/16 just do SO much more, not just more faders.
Thanks for the help I received :)
by ansolas on Tue Nov 26, 2019 7:02 am
They have improved the switched in the new Faderport.
All switches (microswitches) tend to "bounce" here, so If I press the Mix button it get triggered 2 times so that teh Mixer is first shown and then immediately hidden again and vice versa.
It only woks if i carefully press and hold the button.
How about the Faderport 16 , they use teh same microswitches in there ?
by Jonnytheshirt on Tue Feb 04, 2020 8:08 am
For future reference - hated the clicky buttons on classic - the new version buttons a good improvement however the clicky rotary encoder now takes the crown - why oh why - smooth motorised faders and not one but two clickity knobs.
No dedicated Save button on the 2018 solo Faderport - the most used button possibly on my FP8 - although you could reprogram an F key (which is mapped as a shift control of FP) to do this perhaps.
Still great and I'd get 2018 hands down.
Apollo Twin Quad MKII | Octo | Studio One Pro 4 | FaderPort 8 Atom | Mac Mini MacBook Air | Komplete S49/A25 | Sphere L22
31 postsPage 2 of 2
1, 2
