Is there any way to render a midi track that follow the chord track? like you can with midi Note FX. I've tried to render instrument track, but doesn't seem to render the notes by the chord track. I would like to be able to render the midi as generated so I can turn off follows chords then make adjustments to the midi track manually.
[ASUS Z97-K 3.30 gigahertz Intel Core i5-4590]
[16 Gig Ram]
[NVIDIA GeForce GTX1050 Ti 1920 X 1080]
[Windows 10 Pro x64]
[Sonar Platinum x64 Lifetime]
[Studio One 4 Pro]
[Notion 6]
[Waves Mercury + Abbey Road & SSL Collection V10]
[Mackie Onyx 400f]
[ YouTube ] [ Rasuresphere II Omnisphere Library & Midi Stems ] [ 10% Off Waves ]
by Trucky on Thu Jun 14, 2018 2:00 pm
Here's a good Chord Track video to check out:
https://youtu.be/elQpKx9n7dI
Windows 10 Pro 64-bit (v1809: Build 17763.134), Studio One 4.1.1 Pro | Notion 6.4 | Universal Control v2.9.2.49805
Dell Inspiron 17 5770 (Intel Core i7-8550U 1.8 GHz, 4GB AMD Radeon 530 Graphics, 16GB RAM, Samsung 850 EVO 1TB SSD
StudioLive Series III 32 v1.9.14636
by JohnBW on Thu Jun 14, 2018 2:40 pm
I'm not quite sure if I follow the use of the term "render" in this question. To me the idea of rendering an instrument track is to render it as an audio track as played through the virtual instrument. Maybe synonymous with mix down, or freezing. in some contexts.
But it appears that you have used the term "render" with the intent of working with rendered MIDI note data in this case.
So are you are looking for something to generate MIDI note data (where no note data currently exists) based on the chords in the chord track?
As far as I know the chord track only alters existing MIDI note data that you have either played, or entered, into the track.
I think that video in the link above is very helpful.
DAWs: Studio One Pro v4.1.1 and others ... Other: Notion 6; Overture; Band in a Box; AIR Ignite Plugins: AIR Complete; Akai VIP; Biotek 2; Cakewalk; iZotope Iris 2; Miroslav Philharmonik 2 CE; SampleTank 3; SONiVOX; SynthMaster everything; Syntronik; u-he; Waves; many others OS: Win10 Pro x64 1803 System: Homebuilt Asus; i3 3.4Ghz; 8GB DDR3; Intel HD Graphics; Dual Monitors; Samsung EVO 850 SSD, 250GB; WD 1.0TB 7200rpm; PCIe FireWire Audio: M-Audio FW-410 Controllers: A-300PRO; Alesis VX49; CME Xkey Hardware: Roland JV880; JV1080; XP-30; Alesis QS-6; Casio CZ-1000
by markrobotham on Thu Jun 14, 2018 2:48 pm
Thanks for the reply, I did see that video when it first came out, but doesn't answer my question. Yes I mean bounce the midi as midi but with what the chord track has supplied, rather like when you use the arp in not FX, if you render, it renders the midi with the arp as midi note data. Maybe it`s not possible at this time?
EDIT:
Actually just had a thought and just tried something. It is possible by saving the project as a midi file, then re-importing the midi. Would be just quicker though if we could render it, just like Note FX.
[16 Gig Ram]
[Studio One 4 Pro]
[Notion 6]
[Mackie Onyx 400f]
by JohnBW on Thu Jun 14, 2018 4:15 pm
It looks like if you already have MIDI note data in a track, and that track is set to follow the chord track changes, it would automatically render the changes in place according to the chord track in real-time. No offline renders, or export/import needed.
by niles on Thu Jun 14, 2018 5:42 pm
markrobotham wroteI would like to be able to render the midi as generated so I can turn off follows chords then make adjustments to the midi track manually.
Musical Functions > Freeze Pitch
OS: Windows 7 Pro x64 | HW: P9X79 • i7 3930K • 16GB • HD6450 (WQHD) • RME AIO
by markrobotham on Fri Jun 15, 2018 5:24 am
Excellent, thank you! :-)
[16 Gig Ram]
[Studio One 4 Pro]
[Notion 6]
[Mackie Onyx 400f]
Users browsing this forum: kenstrahl, raymondwhitejr, snb1 and 26 guests
