34 postsPage 2 of 2
1, 2
raymondwave wrote1) Yes, but it works with proper chords only.
2) See the attached image, I have an arp that plays Dm until at the end there is one note out of the chord. If there was a way to tell studio one "this is a Dm chord" it might be able to understand that it must not touch it when the chord track plays Dm and transpose that whole sequence properly to other chords when needed, that one "off note" would be moved in relation to the chord.
3) So I'm saying (or have now understood) that it works with 100% exact chords only.
4) if there is no way to incorporate melodies, harmonies or so. I know they couldn't always transpose perfectly anyway, but for sketching purposes this would be cool and if you could print/render the chords after you are set, you could make the final adjustments to everything that didn't quite match.
1) It shifts all the notes in the track to the "follow mode". Have you tried the other two for Instruments?
2) If you want to preserve a Note or even an Event within a track set to follow that would be a Feature request. Workarounds would be to but your the melodies you wan exactly preserved on a sperate track and turn follow off.
3) See (1)
4) Another FR
1) For HELP Read the Manual.
2) Create a SUPPORT TICKET. "Select Submit a Request".
3) For Comunity Help add your specs to your SIGNATURE AND.
Include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce
Detailed how to HERE.
by jpettit on Fri May 25, 2018 11:07 am
Jonny Lipsham demonstrates both audio and Instrument detection and changing chords/transposing.
One minor update, at end Circle of Fifth #/b spelling is based on your root key.
by jpettit on Fri May 25, 2018 11:09 am
Good overview form Marcus Huyskens.
by JohnBW on Fri May 25, 2018 2:45 pm
Thanks, Jeff!!! :+1
I also noticed that Groove3 just put up a Studio One 4 Advanced tutorial. The first two videos are free samples and cover chord track overview and setting up the chord track.
https://www.groove3.com/tutorials/Studio-One-4-Advanced
DAWs: Studio One v3.5.5; Sonar Platinum; Tracktion Waveform; Ableton Live Other: Notion 6; Overture; Band in a Box; AIR Ignite Plugins: AIR Collection; Akai VIP; Cakewalk; iZotope Iris 2; SampleTank 3; SONiVOX Collection; SynthMaster bundle; Syntronik; Tracktion; Waves OS: Win10 Pro x64 1703 System: Homebuilt Asus; i3 3.4Ghz; 8GB DDR3; Intel HD Graphics; Dual Monitors; Samsung EVO 850 SSD, 250GB; WD 1.0TB 7200rpm; PCIe FireWire Audio: M-Audio FW-410 Controllers: A-300PRO; Alesis VX49; CME Xkey Hardware: Roland JV880; JV1080; XP-30; Alesis QS-6; Casio CZ-1000
by ericbiggins on Sat May 26, 2018 9:29 am
jpettit wrote
ericbiggins wroteThanks for the the work. I have been trying to get an answer from Presonus on this but so far nothing, perhaps you can help.
How can Chord track tuning be change to reflect alternative tunings? I tune down a half step and also use drop D tuning at times as well as some open tunings and I would like when I play a E for it show as a E not Eb. Is there anyway to change the tuning without affecting the picth going back up a half step?
I think you mean change key but not the actual data. No, but please add an FR.
In the case of dropped tuning you are playing an Eb
Thank you very much for your response. Yes I understand I am actually playing a Eb, but I don't want to think in a flat key. I only play tuned down because of severe neuropathy which causes muscle weakness. I would like to know and still haven't heard from Presonus is if I can change the tuning of the chord wheel without affecting the pitch. So I can put in that I'm playing a half step down or any step and it automatically transposes the chord names as standard with out stretching the audio. Similar to how I can set my tuner for a 1/2 step down and a Eb reads as E
I'm not sure if I'm communicating this clearly or how to communicate it.
by jpettit on Sat May 26, 2018 2:16 pm
Perfectly understandable.
This is a new feature and it is best to create an FR for shifting chords with out shifting the key.
Use cases
Drop tuning
Some flat tuned instruments
Capo chords.
by hendrik84 on Sat May 26, 2018 3:49 pm
Does the Chord Track not detect chords with a different bass note?
I recorded myself playing D with F# in bass but the software only gave me the D chord?
by jpettit on Sat May 26, 2018 4:30 pm
hendrik84 wroteDoes the Chord Track not detect chords with a different bass note?
Are you talking about Audio Detection or Instrument Detection or Chord Selector Input Detection?
There is a lot to answering what and why.
1) the timing of the notes.
2) the track type
3) the method of detection
by jpettit on Sat May 26, 2018 4:38 pm
To ALL with formal music theory training (not me ;-) )
The accuracy of the chord naming/spelling is well at an initial release level and will improve over time. ;)
Although there was a ton of work put into it, some of it is not totally under the immediate control of Presonus.
The MIDI input/ Instrument track algorithms are.
The Audio track detection is 3rd party code and as such improvement rates will vary.
This will compound as ARA2 plugins are released that supports the Chord Track.
Just wanted people to be aware of the challenges.
Thanks
by briandeeley on Sun May 27, 2018 12:50 pm
Just excellent. Many thanks!
by Orbit-50 on Mon May 28, 2018 9:27 pm
Thank you very much for this. I love manuals!
by dmitrypetrenko on Tue May 29, 2018 4:57 am
Thank you!
by TomTama on Thu May 31, 2018 6:15 am
Thank you!!!
by jpettit on Sat Jun 16, 2018 12:35 pm
34 postsPage 2 of 2
1, 2
