So, I promised I would post an audio demo...
This is Notion driving Hauptwerk ( http://www.hauptwerk.com ) a software-based pipe organ software, the sampler was loaded with the Notre-Dame de Metz Mutin/Cavaille-Coll sampleset. http://www.contrebombarde.com/concerthall/music/29758 I made a custom rule set based on my setup (controllers and triggers are adjustable and specific to my setup, so not something that is useful to share, although I'd be happy to give pointers if anyone wants them) I did a fair amount of note-length tweaking on the sequencer staff to make repeated notes and phrasing sound more idiomatic, and I "performed" the score with NTempo to craft my interpretation - that proved much quicker than trying to do it with tempo alterations. What do you think? - Jonathan
Jonathan Orwig
http://www.evensongmusic.net Composer, organist, church musician Twin Cities area MN, USA Dual Xeon Mac Pro (2x4 cores) 12gb i7 PC 24gb for Hauptwerk GPO, Composer Cloud |
Sounds great! If I had to make one comment it seems a bit muffled. Maybe some EQ to push the high end a bit?
iMac 27" 3.6 ghz I7 quad core 32 gb RAM Fusion Drive
macOS Mojave 10.14 2 - 500 gb + 1 tb external SSD for sample libraries ResidentAudio T2 Thunderbolt audio interface Nektar Panorama P1 control surface Nektar Impact 49-key MIDI keyboard Focal CMS40 near-field monitors JBL LSR310S subwoofer Notion 6 + Studio One 4 Pro http://www.tensivity.com |
michaelmyers1 wroteSounds great! If I had to make one comment it seems a bit muffled. Maybe some EQ to push the high end a bit? On a virtual instrument other than this, yes I might. However, this is really how a pipe organ of this design and manufacture sounds when choosing to use the stops I'm using. (I'm a classically trained organist, so I am probably a bit fussy about stuff like this ![]() Every pipe organ is unique - designed to work in the room for which it is built. And, there are a dizzying number of styles, philosophies, eras, etc. of organ building. So, pulling the same stops on one instrument is not going to sound exactly the same as on another. The stop names do give a general idea how they should sound, but when approaching an unfamiliar instrument and venue, it's basically "orchestrating on the fly" to get the sounds you have in your mind's ear. (Probably way more than you wanted to know) ![]() Best, - J
Jonathan Orwig
Interesting!
I've always been fascinated with pipe organs. I think it's the fact that I'm an architect, and a pipe organ is really about the closest thing to musical architecture as you can get. I designed a church with a planned pipe organ from Orgelbau Klais in Bonn, but unfortunately it was never built. It was very interesting to work with them on the planning and design of the instrument and how it would fit the sanctuary. How do you go about modeling the room in which the organ is placed with this instrument? Is there convolution reverb that emulates certain churches? I once downloaded a trial version but never really got too deeply into it, as it was a tremendous resource drag... Best, Michael
michaelmyers1 wroteInteresting! Well, the "room modeling" is a huge can of worms. ![]() Organists are, as a breed very picky about digital recreations of their instrument. The one thing that sets Hauptwerk apart is the ability to record the sample sets in the space the organ is in, and (depending on the skill of the recording engineer) capture the acoustics of the room. Because the pipe organ can be thousands of sound sources all in slightly different places, getting a convincing sound with convolved reverb is difficult, and most organists can tell... So, in this case, the organ you heard was played with the acoustics of the room, built into the set. The sampling process is labor-intensive to capture medium and short release tails as well as long notes. Then, add in the fact that now the purists are demanding 4 or 6 channel surround, and you have 3x the editing work. (I've sampled 3 complete organs so far for the software, so...) HW is a resource hog, I'll admit. The reason is that for realism's sake (and needing to process so many samples with minimal latency) everything has to be loaded into RAM - no streaming whatsoever. My experience has been that if you want to use it as a virtual instrument, you almost have to have a separate machine to run it, especially if you are using a large instrument (some of the bigger organs need upwards of 64-80gb of ram to load, and a substantial processor - at least 8 cores) The good news is that if you load an organ with a drier acoustic, the processing and RAM needs decrease significantly. And, for those of us who do virtual orchestrating, we want control of the acoustics anyway, so we can match the instruments to each other, and place them in the same "space". Again, probably way more than you wanted to know, but.... ![]()
Jonathan Orwig
