I was using my 1818VSL a few years ago with Audiobox, but sinced performed a fresh install of Windows 10. Thefore, I installed Universal Control 2.0.2, performed the firmware update as suggested, and my 1818VSL is recognised.
Alas, the USB sync LED doesn't light up blue as it did before, and only flashes red when I turn it on. Also, I can't seem to record anything with my mics, either plugging in headphones or on StudioLive.
Note: When I test my 7/8 channel in Windows sound settings, I can hear the audio sample in my headphones.
Config:
Windows 10 64 bits, Presonus 1818VSL.
Thanks in advance for your help!
by cristofe on Mon May 22, 2017 11:32 am
Sounds like perhaps the install did not go properly. Have you performed a proper uninstall/reinstall?
http://support.presonus.com/hc/en-us/articles/210044673-How-do-I-uninstall-and-reinstall-my-AudioBox-drivers-in-Windows-8-or-Windows-10-
It could be a number of other issues as well. Have you optimized your pc for audio production?
Have you disabled wi-fi? Are you plugged into a USB2 or USB3 port?
by adrienharnay on Mon May 22, 2017 2:20 pm
I installed the software on a clean install, but for the sport I did a clean uninstall/reinstall, still no luck.
I didn't do any optimization for audio production, wi-fi is disabled, and I am plugged to a USB2 port.
I also read the manual.
by cristofe on Tue May 23, 2017 11:51 am
Well then, if you have not already done so, I suggest you open a support ticket. They'll get you sorted out.
by adrienharnay on Sun May 28, 2017 8:05 am
Thanks, I've done that, but so far it's just a ping pong of the same manipulations without real results... Wait & See for the next answer on Monday :roll:
by magnusholen on Mon Mar 18, 2019 5:52 pm
Did this get resolved?
PC - i5 6600k gigabyte z170-mx 16gb ddr ram win10 64bit
Reaper
Presonus 1818VSL
Roland TD-12
by adrienharnay on Mon Mar 18, 2019 6:08 pm
Well, no... I just gave up on the Presonus support
