I would love for Presonus to add Studio One instruments , effects , and sounds , as well as the ability to use 3rd party audio apps , to record into Capture . Expand the track count passed 32 , also importing of sounds and samples , and the arranger track and scratch pad . Turn Capture into a full mobile DAW , and transfer everything to Studio One on desktop and laptop .
by matthewgorman on Thu Mar 23, 2017 3:29 pm
Sorry, I should have clarified. Go to:
answers.presonus.com
Find the Capture Mobile category, and search for an existing request for what you want. If there is already one, vote it up. If none exist, create a new one.
S1Pro V4
by cristofe on Fri Mar 24, 2017 11:00 am
That is not likely to happen. The point of Capture is in it's name. Simple audio recording WITHOUT all the bells and whistles, (and higher CPU overhead), of a full DAW. That being said, I wouldn't mind seeing a mobile version of Studio One for both iOS and Android.
by sjc193 on Fri Mar 24, 2017 12:09 pm
What is it about StudioOne that is not as Mobile as Capture?
Just seems to me that you are asking for StudioOne with Capture's name. The list of additions you're asking for in Capture in just one sentence amount to, well, Studio One.
Mastering the use of Templates in S1 can have you ready to record anything anywhere in seconds, including using all the additions you mentioned.
That said, I use capture because I like my recorded audio tracks to be raw so I can post process them at a later date.
Steve
StudioLive RM32AI
ASUS RT-N66U Dual Band Router
4 EV ZLX-12P's, 1 TurboSound iX15, 2 Yamaha S115V's
1 Crest Pro-Lite 7.5 (7500 watts) amp, 2 Behringer EP4000 amps
10 58/57 mics, 1 SM86, 1 sE8, 1 sE2200, 1 AT2020, 2 AT2021
1 beta52 kick mic, 2 e609, 2 Radial J48 DI's, 1 PRO48 DI
2 4Bar lights, 1 4Play, 1 6Spot, 1 fog machine
by ernestortega on Tue Feb 26, 2019 3:21 am
No shouldn't happen.It's name itself specifies point of Capture.Version of studio one for both ios and android is better,u should hope for it.MyBKExperience
by veldermike on Sat Sep 14, 2019 8:39 am
I also have the same issue and now looking for the solution. I hope I will get good solution from this community.
by mianovah on Sat May 16, 2020 12:47 am
In most of the Android devices, the easiest way of capturing a screen is to press the Volume Down (up or down) and Power button at the same time, hold it for a second and you will have your screenshot saved in your photo gallery. Why is it good to capture the screen using the buttons on the device: It's fast and easy.https://www-mybkexperience.me/
