I have an instrument part where I want to create a pong delay effect on the last note of the MIDI clip. Splitting the events and assigning an Event fX to the last note would be the best option, but you can't assign Event fX to instrument parts.
So I added a delay as an Insert FX to the track and then automated the "Bypass" so that just the last note isn't bypassed. Unfortunately, when the bypass turns off, the delay effect is also sounding the previous notes. This makes sense because the effect is basically still processing the track when it's bypassed, and it just becomes audible when the bypass is turned off. I tried moving the last note to a separate track and sending to the instrument, but this doesn't help because if I add an effect it will add it to both tracks still (won't let me violate the "No Event FX" rule). Anyway, there has to be an easy way to do this. I don't really want to use a separate fX channel and send. I also don't want to load a whole new instance of the synth just to add the delay effect. Is there some easy way to do this? |
Automate the on/off rather than the bypass?
Garry Knight
Studio One 3 Professional Melodyne Editor 4, NI Komplete 11 Focusrite Scarlett 2i4 audio interface Windows 10 Professional 64-bit, 16 GB RAM, Core i5 Microsoft Surface Pro 3, Core i7, 8GB RAM, 128 GB SSD Nektar Impact LX49+, Samson Graphite 25, and Korg microKey 25 MIDI controllers Novation ZeRO SL MkII mixing control surface Korg nanoKontrol 2 mixing control surface Reaper, Logic Pro X, GarageBand https://soundcloud.com/garryknight |
Add MIDI notes for the delay sounds.
Copy and paste additional MIDI notes after the original note for the delayed sounds. As for the volume level and tail of the delayed notes, reduce the velocity, expression and or volume levels using continuous controllers as a fadeout. Reset the levels after the delay effect if the music is to continue. ,Newberry |
I didn't totally understand that. Are you saying that I should basically simulate a delay effect by copying and pasting additional MIDI notes and use volume automation to fade out the additional notes? If so, that's a good idea.
It's a bit of a workaround, as I'd have to add pan automation for ping-pong delay, etc. But, it will get the job done. Thanks! |
Stuff like this is usually reserved for mixing, and mixing is usually done after instrument tracks have been transformed to audio, and audio tracks are easier to handle for cases like this. Personally, I would render the instrument and copy the last note (audio) to a separate track with a delay insert on it, or I would use event fx on this new region, but automating a send is the best way if you don't want to render anything (or copy the whole instrument), and automation is super easy.
You can create the send and return channel by dragging the plugin from the browser and into the send area of your instrument. An automation track can be created simply by touching the parameter and then pressing the "A" box in the cobtrol link window in the upper left hand corner of the DAW. I know you were looking for something easier, but this is actually quite easy once you've found a routine for it, and it's well worth implementing. |
I had an Akai box once that was a midi delay.
So repeated the notes fading out somehow.
niles wroterlared wroteUnfortunately, can't automate on/off.Garryknight is referring to automating the send itself (Send Mute). Thanks, Niles. I could have phrased that better.
Garry Knight
Skaperverket wroteStuff like this is usually reserved for mixing, and mixing is usually done after instrument tracks have been transformed to audio, and audio tracks are easier to handle for cases like this. Personally, I would render the instrument and copy the last note (audio) to a separate track with a delay insert on it, or I would use event fx on this new region, but automating a send is the best way if you don't want to render anything (or copy the whole instrument), and automation is super easy. OK actually this sounds pretty easy, I'll give it a shot. I like this better than the idea of adding additionally MIDI notes. Thanks! |
Users browsing this forum: BobF and 12 guests
