Includes StudioLive 312Ai, 315Ai 328Ai and SL18sAi
Still having issues with one of my 315ai. I posted about it earlier, so I won't drone on.
Is there a way to reset the speaker to the original factory settings?
My thought was to roll back to factory settings then re-try the firmware update.
Thanks,
Rich
by sjc193 on Mon Apr 11, 2016 2:07 pm
http://support.presonus.com/entries/669 ... structions
That is the best Info I could find on it, hope it helps, if you have recently updated the firmware via usb stick, go ahead and try it again, couldn't hurt
Steve
StudioLive RM32AI
ASUS RT-N66U Dual Band Router
4 EV ZLX-12P's, 1 TurboSound iX15, 2 Yamaha S115V's
1 Crest Pro-Lite 7.5 (7500 watts) amp, 2 Behringer EP4000 amps
10 58/57 mics, 1 SM86, 1 sE8, 1 sE2200, 1 AT2020, 2 AT2021
1 beta52 kick mic, 2 e609, 2 Radial J48 DI's, 1 PRO48 DI
2 4Bar lights, 1 4Play, 1 6Spot, 1 fog machine
by RichStudio on Mon Apr 11, 2016 2:11 pm
Thanks Steve. I did all that. May mess with the speaker later today with an Ethernet cable connection.
Best,
Rich
by rpark on Sat May 21, 2016 4:38 pm
I had a similar issue with a firmware, and kept working at it (re-downloaded a fresh copy of the firmware, used different thumb drives, etc). The speaker (a 328) eventually came back to life and sounds fine now. I am not positive what I was doing wrong, or finally did right. Just keep at it, sometimes it takes a while.
by liviuvalentinpopa on Mon Sep 18, 2017 4:48 pm
how do I reset the presonus studiolive factory 315ai? I updated erroneously and all the lights were on and with a strange noise in the loudspeaker and no longer works-no more is heard than clicks I tried to update correctly after that but did not come back - please leave an urgent reply - thank you
cron
