So I have a focusrite 2i2 as my interface. however everytime i load studio one and try to find the guitar rig 5 pro library to add it, it says it couldn't be found. does it has to be run as an plugin or something can anyone tell me how to do this?
You don't say what version of Studio One? In v2 you need at least Producer to use 3rd party plug-ins, v3 you must have Pro or purchase an add-on to Artist for like $100 bucks.
Studio One Pro 6.5 | Apollo Twin Duo USB | Win10 | AMD Ryzen 3 | 32GB RAM | SSDs SoundCloud | Project 9732 | Komplex 2 |
miked7 wroteYou don't say what version of Studio One? In v2 you need at least Producer to use 3rd party plug-ins, v3 you must have Pro or purchase an add-on to Artist for like $100 bucks. I have studio one producer.. sorry if I didn't mentioned earlier. so.. I guess you must use it as a plugin? I have tried to find it on the list of instruments and plugins but it won't show up. thanks |
Yes, I use it as a plug-in.
Things to check: 1. Make sure the "Guitar Rig 5.dll" is in < C:\Program Files\Vstplugins > (Windows 7 for me...) It doesn't HAVE to be in this folder, you can point Studio One to alternate locations too. 2. Go to the menu at the top called "Studio One", then "Options...". Click the "Locations" icon, then the "VST Plug-Ins tab and make sure the above directory is there. 3. If those are all set, somewhere there is an option to "re-scan" your plug-ins - I forget where at the moment, sorry. 4. If all of THAT is set, then to use it as a plug-in, go to the mixing channel where you want to use it, click the + to add an insert, and it should show up in that list. It has a little "FX/VST" icons near the bottom of my list. You can also use the "Browse" (activated in the lower right corner of Studio One) to find it. That's about all I can remember off the top of my head. There are guys on here a LOT more knowledgeable than me, hopefully one of them will chime in with more trouble shooting tips if this doesn't get you going....
Here you go: viewtopic.php?p=72579#p72579
miked7 wroteYes, I use it as a plug-in. I only found the guitar rig 5.exe file not .dll I bought komplete 9.. did i miss something during installation? |
IIRC Guitar Rig needs to be run in stand-alone mode before using as a VST. While it is open you should set all of your options and make sure you get it registered correctly.
I think most NI plugs (including Maschine) need to be run outside of your DAW host (outside meaning standalone). If you right-click the .exe file you found and pick Run as Administrator you should be able to get it up and running. Michael Morgan | pearl hour project --------------------------------------------------------------- Intel i7-2600 @ 3.4GHz | 16G ram Windows 10 | Studio One v3.3.1 | Live 9.6 (all software 64 bit) RME Fireface UFX | Nektar Panorama P1 | AKAI MPK25 | M-Audio Keystation 88 I Maschine 2 | Fader Port 8 |
pmsezztfs wroteI think most NI plugs (including Maschine) need to be run outside of your DAW host (outside meaning standalone). If you right-click the .exe file you found and pick Run as Administrator you should be able to get it up and running. No, this is not required. The plugins are registered through the Service Center and don't need to be run standalone first. (Komplete 10 Ultimate owner here, I have literally never started anything in the NI lineup in standalone mode, everything works normally as a plugin, including Guitar Rig.) |
Nokatus wrotepmsezztfs wroteI think most NI plugs (including Maschine) need to be run outside of your DAW host (outside meaning standalone). If you right-click the .exe file you found and pick Run as Administrator you should be able to get it up and running. But like i Mentioned... I can't find the .dll file that you mentioned.. i could only find the .exe |
I think you missed something on the install but probably more likely it put the .dll in a directory that is not in your Studio On scan path.
Search for it. Here is a great local search tool. http://www.voidtools.com/
GuitarRig5.dll
Assuming, as I don't have it installed on my computer but the .dll file is the VST. You could also search for GuitarRig*.dll
Users browsing this forum: SkylineUK and 10 guests
