Hello, I wonder if anyone else has noticed some channels of their FS2626 have a very low frequency noise?
I posted the full details in the digimax forum here: viewtopic.php?f=121&t=17081 Since my digimax FS has a similar problem. Since some channels are far worse than others and since the freq is very low approx 1.5HZ i think it may be a ground problem in design or a failure. You have to amplify the signal quite a bit to see the waveform but it is noticeable in quiet passages of music. Thanks for reading and especially if you have any ideas. |
i'm not sure if i have a similar issue, but i noticed that the levelmeter on Channel2 showed a signal randomly even if there's nothing connected to its input. (i didn't check it in detail because i dind't use this channel) But as this phenomen occurs just on this Channel one of my FS2626 i assumed that it might be either related to my wiring (maybe Grounding issue on Chn2 inserts), or theres a defect on this single channel. Anyway there are no inserts for Chn4&5 :-/ so i will follow your thread maybe theres something else, i didn't notice. BR Dominik |
I've had similar issues with my FS 26x26 Digimax LT combo BUT.....only when using it in a mobile situation. Many venues have horrid wiring!! Bad grounding can introduce all sorts of noise as can other electronic devices running on the same circuit. At my home studio all the wiring is recent and above code standards and I also use top quality power conditioners.....no issues whatsoever.
i did record the channel i mentioned above right now. It is not e definded Frequency just noise more like the Clicks and Pops you have when having sync problems. (find WAV attached) Anyway i have to check the Wiring/Grounding more detailed. BR Dominik
Hi
Cellphone noise would happen on other channels too, i also moved the rack to different places in the room which had not any influence on that noise. As it seems that this Firestudio seems to cause some sync issues with DigiMaxFS and cascaded Firestudio2626 im quite shure that this device has a hardwareproblem So as there is no official support for this device i think i have to open it and have a look on my own. Even if this might be a needless qestion but is there something like a Service/repair guide for this legacy FireStudio? |
