Just saw my board shipped yesterday
Replaced DSP BOARD. Hopefully this one has a few good years in it. I also received my new- refurbished unit as well and have had it on the bench playing music for two days solid with no issues, so I think it's ready for service! Perhaps later, I can trade them all in for a RM. But I still don't trust that wireless stuff in the DC aria. |
My buddy just got a used 16.4.2, and it hasnt worked right since we first hooked it up. I had the levels cranked on everything, should have been blowing the glass out the place, but output was very low, amps were hardly getting any signal. Will DSP board failure also cause this? The board still functions and doesnt freeze, just minimal output. And yes i know how to use the board and am aware of the output knobs on the output jack. Thanks.
Did you zero out the board to make sure there's no limiter kicking in?
I usually load the "Zero Out Board Reset" scene.
This is a heat problem I have had mine 6 years and no issue besides replacing the faders last month
Mine is in a road case but I always lift up the back of the mixer so air can circulate under Neath The power supply is mounted on the bottom of the mixer and these desks get very hot underneath a design flaw I reckon I think a little desk fan blowing into a vent would be a help Heat kills electronics |
I had two DSP boards fail on my 16.4.2 but still upgraded to a 16.4.2 AI which has worked without a problem since.
Unlike the 16.4.2 there are cooling fans in the 16.4.2AI blowing air across the PSU. I ended up disconnecting the one on the left of the board to reduce noise in the studio but have still had no problems. |
Same problem here, with new generation 16.4.2. Bought on March 2015, problem in april 2016 (yeah, just a month past the warranty). No answers from presonus about this problem that we can see its a serial issue with the DSP. I live in Brazil, hot country, but the console was used just indoors with AC all the time. Looks like they build this board in Canada just to use in canada temperatures.
Im so sad with presonus, i love my board but i wont keep it after all these issues and hundreds of costumers complaining about the same issue without any explanation form presonus. |
Mine has just died again.
£632.00 to fix it. I've asked what the cost would be if they just sent it back to me unfixed and was told around £100 (£84 for an hours work to identify the problem and the rest on p&p) If I just leave the desk with them, they will waiver any costs. As I won't ever trust the desk again, even if it gets fixed, I'm thinking of just leaving it with them and forgetting I ever owned it. What a complete waste of money my 16 4 2 has been!! In the four years I've owned it, I've done about 20 gigs with it and it let me down on half of them. |
Desolder the flash memory from the dsp card and make a copy of its contents when it is in a working condition.
When the console dies replace the flash memory with a new one where you have programmed it with your backup image. Rince and repeat every couple of years...
Skip
Tangledown wroteGreat advice, but you may as we'll be speaking double Dutch. The problem is that you need two things. 1) A flash memory from a working mixer that is not yet corrupt. This because you need to extract valid data. 2) A flash programming device. This is a little more difficult to find. But when you do then you can copy the data to some extra spare flash memories as spares Getting access to the dsp card where the flash memory is soldered is a slight hassle involving a lot of screws and cursing. You need to master the skill of de-soldering/soldering surface mount components. On the bright side you only need to replace the flash memory every 3yrs or so depending on how much you use the mixer.
I realize that this post is several years later but I"m having a similar problem and I also think it's heat related. The thing is, mine appears to be more complicated. I have 2 computers connected to it but only one is using the Firewire port. The other, my online computer just uses the tape in for audio. I have a switch that changes things so that I can use the mouse, keyboard and monitor for both computers.About 7 or so months ago the first problem started. I'd be recording using my music computer and when I switched to my Online computer, all audio would stop and even if I switched back, still no sound from my powered studio monitors.
Then I found out that if I powered down my mixer and turned it back on about 10 seconds later, the display on the mixer wouldn't come up and no audio anywhere. It sucks because I'm used to it and really don't want to have to get another mixer, knowing as well that this one is more of a boat anchor than anything. Any ideas would be great! Thanks in advance! Jeremy Thornton AKA Jeremykeys |
