265 postsPage 9 of 14
1 ... 6, 7, 8, 9, 10, 11, 12 ... 14
I'd like to see gain reduction values next to the compression gain reduction meter.
The number values that are inside the compressor threshold are only to indicate the threshold level and not gain reduction.
The meter that shows the gain reduction is pointless as it has no values to show what you are reducing
I have both AI and RM mixers and at least on the board I can tell what gain reduction is happening by number value, but in UC Surface for both AI and RM there is no representation
by [email protected] on Thu Jul 02, 2015 8:29 pm
Being able to have a compressor set 'post' main outputs fader would be nice, then I can finally get rid of the DBX166XL out of my rack.
by summitcn on Fri Jul 03, 2015 5:01 am
[email protected] wroteBeing able to have a compressor set 'post' main outputs fader would be nice, then I can finally get rid of the DBX166XL out of my rack.
The compressor on the Main's Fat Channel should have the same effect as putting a compressor inline with the mixer and amps/speakers.
by mrubin0818 on Sat Jul 04, 2015 8:43 pm
A way to parallel compress would be nice. using soft ware and changing routing for channels instead of a hardware xlr Y. I dont mind using an xlr Y but it would be nice to do it with the rm32 hardware instead. :+1
by seanmcdaniel on Sun Jul 05, 2015 9:33 am
Couldn't you just assign a channel to a sub group, compress the subgroup and then keep both the channel and the subgroup assigned to the mains?
by mwright137 on Sun Jul 05, 2015 1:17 pm
seanmcdaniel wroteCouldn't you just assign a channel to a sub group, compress the subgroup and then keep both the channel and the subgroup assigned to the mains?
Yes. This is exactly how I do it.
My Website
by Karyn on Mon Jul 06, 2015 7:08 am
When an RM is networked with AVB to a console, the mains return is injected directly before the output amp. This leaves the mains output meters in Surface displaying a signal (the on board mixer main) that can't ever be heard other than through the headphone socket. Also, when connecting headphones to the RM and selecting "main" with the front panel button, you get the internal mains bus (goes nowhere) and not the actual mains return from FOH. (this confused a friend of mine for quite a while...)
It would be better if the returned signal was injected at the point the headphones are connected, so anyone on stage could plug in headphones to hear exactly what is supposed to be coming out of the mains and also see it metered in Surface. Currently this is only available at the FOH console...
Karyn
Sonar Platinum, Studio One.
http://refer.waves.com/dzDVn
Dante Level2 certified.
by Karyn on Mon Jul 06, 2015 7:11 am
An option to use the front panel LEDs as an output meter for the mains.
Karyn
by angusgolding on Tue Jul 07, 2015 6:14 pm
A 'Quick lock' button to lock the screen, an undo function would be good.
And if someone can tell me how to load an eq without changing the description and icon on the channel strip, please elaborate.
I would like a SM57 type icon. or the ability to make your own icon.
by Dale Christenson on Wed Jul 08, 2015 8:08 am
The ability to create icons for channels is a huge issue. I would imagine for many of us.
Sound 4-U! reinforcement and mobile recording serving Tulsa and surrounding areas.
Dale Christenson
918.261.7263
StudioLive RM32ai
StudioLive RML32ai
CS18ai
MOTU AVB switch
ULT15 x6
ULT18 x2
SL AI328 speakers x4
StudioLive 16.4.2 classic
Windows 8.1 SSD computer with UC Surface, Capture2, and StudioOne2 Producer
by markstar on Thu Jul 09, 2015 4:57 am
On the sl classic turning the ipad upright gave you a complete channel view I would like to see that returned
by Dale Christenson on Thu Jul 09, 2015 8:56 am
markstar wroteOn the sl classic turning the ipad upright gave you a complete channel view I would like to see that returned
+100
Dale Christenson
918.261.7263
StudioLive RM32ai
StudioLive RML32ai
CS18ai
MOTU AVB switch
ULT15 x6
ULT18 x2
by bjmccaskil on Thu Jul 09, 2015 11:04 am
I was just using my RM for the first time in a studio type situation. Capture was a great help in simplifying a hectic environment.
Two requests:
Turning digital return on and off en masse with a single button in Capture was a lifesaver. But for redoing individual tracks it would be great to have the same convenient control over individual inputs. It would be nice to have a digital return button for each channel sitting there next to the Recording Arm button, with a similar All On/All Off toggle at the top.
It would also be helpful to be able to (re)record tracks to layers right in Capture, and have all the layers later load into Studio One. We don't want to start bloating Capture, but I think this would be worth doing.
Thanks.
by bjmccaskil on Thu Jul 09, 2015 1:03 pm
And, as many times as said before, the ability to name Quick Scenes would be great.
by bjmccaskil on Thu Jul 09, 2015 1:11 pm
May as well get it all off my chest. This one would be icing, but so useful.
It would be cool if somewhere associated with the Scene menus there could be a small Text Edit utility that would permit us to write a few notes and save these notes with the scene. Despite 100% save and recall, I still have to keep an offline notebook with DI types, mic's used, amps and settings, etc. Being able to save such notes with the scene would be chocolate icing.
by rolandclarke on Tue Jul 14, 2015 3:58 am
I haven't tried that, but I would think you may have to watch that there isn't a delay on the subgroup in comparison to the channel, otherwise you may have trouble with comb filtering.
by shaneboaden on Tue Jul 14, 2015 4:14 am
The sub groups ONLY have a delay on them if you change their delay settings in the system menu, otherwise it is fone
by warlockscript on Thu Jul 16, 2015 1:34 am
can't place RM32 yet on stage unless anyone figured out how to enable solo/cue on any controlling device.
by dougwatson on Thu Jul 16, 2015 6:39 am
how about using a wireless in ear or headphone setup to connect to the headphone jack? We do that at our facility. you can control everything from any of the UC Surface interfaces...
StudioLive 24.4.2 StudioLive RM32AI MacBookPro OSX 10.8.5 Mac Mini OSX 10.9.5 (In Rack Case with the RM)
by wozzatpt on Mon Jul 20, 2015 5:30 am
I'd like to make naming channels and outputs quicker and easier- and bring back the facility to bulk edit the names in the settings page on the app
It takes too long- particularly outputs to name them.
Users browsing this forum: No registered users and 120 guests
