I recently changed around my rack and when plugging the firewire cable back in, I plugged it in the wrong way. Stupid I know, but I can't believe that it even let me (as opposed to usb which can only be plugged in one way). Anyway, now the unit will not sync. Is there away I can fix this? Look for a certain part that can be replaced? Schematic maybe? I feel sooooo terrible about this as this unit has done me well for years and I cannot afford to replace it with something new. Any ideas? Thanks!
by Karyn on Mon Jun 01, 2015 12:34 pm
How hard did you have to force it to plug it in the wrong way? Firewire connectors are keyed and you should not be able to do that.
Does the computer still see the firepod? Have you tried a new cable? You may have damaged the conductors in the connector..
Karyn
Sonar Platinum, Studio One.
http://refer.waves.com/dzDVn
Dante Level2 certified.
by rhaigh on Mon Jun 01, 2015 12:54 pm
The firewire connectors on the firepod are very flimsy and it takes no extra force to put it in the wrong way. The cable is fine. The firepod light goes to from blue to red when turned on, but it never goes back to blue. So I guess the computer does not see it.
by cristofe on Mon Jun 01, 2015 4:10 pm
"The firewire connectors on the firepod are very flimsy and it takes no extra force to put it in the wrong way."
First of all, no. Compared to ANY other firewire connectors they most certainly are not any more or less robust. It's a DESIGN flaw. Presonus did not design this connector. How old is this unit? Have these "flimsy" connectors ever failed on their own? Unfortunately this mistake is possible with ANY firewire connector. You're certainly not the first to have done this. It's not impossible with firewire connectors.....USB is designed better to prevent this IMHO. Unfortunately, doing so reverses the pin order and usually fries the port of the unit in question. There is no easy user fix. You either need to have the unit replaced or send it to Presonus for repair. Although, I'm not sure that they can any longer service this unit as it has been discontinued for a LONG time. Parts may no longer be available.
by rhaigh on Mon Jun 01, 2015 4:48 pm
I have other devices which have a much stronger and supported firewire connector than the weak, board supported ones on the firepod. But what's done is done. What I'm wondering, is if anyone knows what components typically get fried when this happens and if there is a schematic of this circuit around anywhere. Maybe build a new port.
by cristofe on Tue Jun 02, 2015 1:32 pm
I don't know of any online. Try calling Presonus Tech Support.
by matthewgorman on Tue Jun 02, 2015 1:57 pm
FWIW, Presonus still provides service for the FIrepods. It a nominal flat rate bench fee, and includes a 12 month warranty post repair. This would be if you are located in the US. Outside the US, repairs are usually handled by the distributor.
You would need to contact tech support for current pricing.
S1Pro V4
by cristofe on Wed Jun 03, 2015 9:19 am
Thanks Matt.....wasn't sure if they still serviced Firepods. :thumbup:
by codamedia on Sat Jun 13, 2015 3:00 pm
I did this on my Firepod as well when I first bought it (used).
Luckily, there are two ports... I just plugged in (properly) to the second one and it syncs without a problem. Frying one port does not fry both (at least not in my case).
Windows 10 Professional, 8 Gig Ram, Q9300 Intel 2.5G CPU, ATI 5400 Video
Firepod Interface, Studio One Artist (64 bit) V2, M-Audio Axiom 49, FaderPort
