STUDIO ONE V3 - Red on record
The playback cursor will turn red when recording is engaged.
House | Dubstep by Thedmncproject
i7 920 | W8.1 x64 | 12GB RAM | Samson | Studio One Pro v2 | Echo Audio Fire 4 | Nvidia GTX 480 |
STUDIO ONE V3 - Automation indicator
A visual indicator (dot) will now appear on FX and Instrument plugin knobs that are being controlled with automation.
db wroteA visual indicator (dot) will now appear on FX and Instrument plugin knobs that are being controlled with automation. Not new actually but different. In V3 the dot has the color of the automation mode.
Sonic Core XITE-1 SCOPE DSP Platform ~ Windows 7 Pro 64-bit@Mac Mini i7 (Late 2012) ~ Studio One Professional 2.6
RME Fireface UCX ~ OS X 10.9.5@MacBook Pro (Mid 2012) ~ Studio One Professional 2.6 -- Try FastMail for better email! |
sunmachine wrotedb wroteA visual indicator (dot) will now appear on FX and Instrument plugin knobs that are being controlled with automation. Your right. Barely visible on some plugins though like the EQ (in v2) but it is an improvement definitely. It is certainly much more visible in V3 ![]()
STUDIO ONE V3 - Arranger Track (Intro)
This offers a quicker event based work flow for easy rearrangement of events on any track. Portions of your song can be moved forward or backward in the time line to taste. A single click on the arranger track button opens the new track type.
STUDIO ONE V3 - Arranger Track (Creating Sections)
Sections can be created with the Paint tool. Simply drag across the Arranger track to create new sections.
STUDIO ONE V3 - Arranger Track (Sections from existing markers)
You can mirror an existing set of markers with your sections. Simply right click on a section and select the following command Create Arranger Sections from Markers
Quick access to the macro controls just click to track number on arrange window.
Submitted by Demo User dereckboatwright from this thread... viewtopic.php?p=46858#p46858
For all of you, Hip-Hop, R&B, Trap and TrapEDM producers out there. . .I made a Multiinstrument that allows you to do hihat rolls with one key! Trap Snare.instrument Hihats.instrument |
If you want to remove your custom thumbnails then find the folder called "snapshots" inside your user data folders in s3. You can even edit the images in the snapshots folder and create your own custom images. Check the picture.
STUDIO ONE V3 - Arranger track (Editing sections in the Inspector)
You can perform different Section Editing tasks from the Inspector Delete Range Duplicate Copy to New Scratch Pad Insert Replace
STUDIO ONE V3 - Arranger track (Renaming sections)
You can easily rename sections in the Inspector Double click on the Section name and change to taste.
STUDIO ONE V3 - Arranger track (Right click to Rename sections)
If you prefer to rename by right clicking, this is also possible from the Arranger track. Simply right click on a section you want to rename and then double click on the name to edit it. Other useful commands are also available from that list.
STUDIO ONE V3 - Arranger track (Fit Section to window)
This is very useful to aid focus on one area of an arranger track at any time. You can expand a Section to fill the time line or fit to window with a simple double click on a Section.
STUDIO ONE V3 - Arranger track (Colours changes Part 1)
1. Right click on any section 2, In the top left of the command menu place your cursor over the coloured box 3. Move your mouse wheel to change the Section colour.
STUDIO ONE V3 - Arranger track (Colours changes Part 2)
Alternatively for a more visual set of options you can use the colour palette. 1. Right click on any section 2, In the top left of the command menu place your cursor over the coloured box 3. Single click to bring up the Colour palette
STUDIO ONE V3 - ROTOR
This FX plugin produces the classic Leslie cabinet sound. Highlights include... 1. Mic Positioning 2. Controls for drive and tone (Horn – Q) 3. Motor Controls (on/off; slow/fast) 4. Virtual Tube preamp
