Routers, Switches, Cabling, Access Points, Repeaters, etc all discussed here
Ok, so it was prolly my fault, but these things are so small that the easiest way to prevent loosing them is to leave them plugged in.
So the other night I was lifting a 328 onto it's stand and I noticed the WiFi dongle was just a mangled stub :( I guess something in the van tried to occupy the same space at the same time :!:
Never mind, I thought, I have a spare taped to the RM32 that doesn't get used (the RM is hardwired to the router). Well, the tape was still there, but no dongle...
So I'm now short by 2 Wifi dongles. Are these things just bog standard cheap generic WiFi dongles? Or are they a specific brand/type/modified that all the Ai gear specifically looks for?
Karyn
Sonar Platinum, Studio One.
http://refer.waves.com/dzDVn
Dante Level2 certified.
by Karyn on Thu May 21, 2015 1:54 am
Anyone? I need to replace the dongles... Can I buy anything I can find at my local store or do I have to buy from PreSonus?
Karyn
by seanbrown2 on Thu May 21, 2015 4:23 am
Replacements from presonus are $19.95 US . that is about as cheap as anything else
http://www.presonus.com/buy/stores/accessories
Last year traded up my 3 firepod pod chain for a RM32AI. just added CS18AI And I am LOVING IT!. The Home Studio set up. Home built. Amd fx 8350 8 core 4400 Mhz liquid cooled. Asus M5A99X-EVO R2 MotherBoard, 16 GB Crucial Ballistix 1866mhz Ram, 120 GB Intel SSD , 1TB Seagate HDD, 4TB HGST NAS HDD, 500 GB Seagate HDD. Windows 7 Pro 64 bit, SiiG DP FireWire 800 3 port PCIe card, tripple monitors 27 inch Asus Monitor / 2 24 Asus inch monitors , Studio one 3 pro, RM32Ai firewire to pc, QSC RMX 2450, RMX 1450, RMX 850. Furman RP-8D power conditioner. Audix Microphones. PDP Platinum Series Drums
by Karyn on Thu May 21, 2015 4:44 am
Yeah, I've seen that. Unfortunately the online store says "domestic sales only" and I'm in UK.
So do I try to find a UK dealer that stocks the "PreSonus" part or will any cheap Wifi dongle do?
Thanks for the reply anyway. :)
Karyn
by roblof on Thu May 21, 2015 5:19 am
If I'm correct the dongle is based upon the
http://www.realtek.com.tw/products/prod ... ProdID=274
So I can only assume that anything based on that would work...
EDIT: Maybe this one http://www.ebay.com/itm/Realtek-RTL8188 ... 0973235744
by Karyn on Thu May 21, 2015 5:58 am
Thanks, based on your suggestion I kept following the links and came up with this although it's a bit pricey at $2.29 + free shipping :P
I may buy a few different brands to see which ones works best.
Karyn
by roblof on Thu May 21, 2015 6:28 am
Karyn wroteThanks, based on your suggestion I kept following the links and came up with this although it's a bit pricey at $2.29 + free shipping :P
Where do you find that this one is based upon the 8188cus? I could not find that in the link you provided...
by Karyn on Thu May 21, 2015 6:42 am
True, I was going by the "suggested alternatives" ebay provides, and the identical packaging. It was more a humorous search for "how cheap can I be" rather than a serious money saving exercise.
I'll get some that actually specify RTL8188cus somewhere in the description.
Thanks for the info, it is most helpful.
Karyn
by Karyn on Thu Jun 04, 2015 5:03 pm
If anyone is interested I bought 5 @ about $5 each (a lot better than $20 in the PreSonus store).
I need to do more hard testing, but at first try they seem to work fine.... and being smaller they should be harder to break!!
Karyn
by roblof on Fri Jun 05, 2015 1:43 am
Karyn wroteIf anyone is interested I bought 5 @ about $5 each (a lot better than $20 in the PreSonus store).
Cool! I wonder if the 8188cu also works...?
by bitonwalstra on Fri Jun 05, 2015 6:05 am
nice 1, got a link mate :?:
Micro PA;
Apple; MacBook Pro 13", Mid 2010, 8Gb RAM, 500Gb SSD, OS X latest version
Apple; iPad 3, 16Gb, iOS latest version
Asus; S300C Notebook PC, 4Gb RAM, 250Gb HD, Windows 8.1
Studio One; v2, Artist
StudioLive; 16.4.2 (sold)
StudioLive; RM16Ai (returned)
Behringer; X32 Producer (sold)
Behringer; XR18 (ordered)
Electro Voice; ZXA1
Heil Sound; PR22, Handi Mic
Lag; 1984 RockLine Bass
by Karyn on Fri Jun 05, 2015 6:36 am
Correction, I paid about $3 each.... :shock:
I found them on ebay, if you do a search there are plenty listed with the same spec.
DISCLAIMER
I have one in an RM32 and one in a SL32 and they appear to work. But I have NOT done any long term testing, or tested for range, or any other testing that you should do before relying on them at a live gig. I'm working on that one.
Karyn
by klypeman on Thu Oct 06, 2016 5:18 am
And now the big question , did they work ??
AMD Ryzen 7 3800X 8-Core 3.90 GHz Windows 10 64bit Home, MacBook Pro + Mini Big Sur, SO 5.5 Pro, SO 6.1.1 Pro, LUNA, Cubase 10.5 Pro, SLIII32, 24.4.2, 16.0.2 FW, Quantum 2626, Faderport 8, FaderPort 16, Atom, Atom SQ, Console 1+Fader 1, UA Apollo Twin TB/USB, Toontrack, NI Komplete 12, ++
by Karyn on Fri Oct 07, 2016 8:20 am
Yes, but I don't use them any more as I've gone full Dante..
Karyn
