Beginner here. See attached screen shot. After much editing, most events on my tracks have turned black, while some events remain the assigned track color. Not sure what I have done! Can someone explain? Much appreciated. Pat
Dell all-in-one desktop.
Audio interface : SSL 2+ I’m a singer-songwriter- performer and guitar teacher. Https://Patriciadaleymusic.com |
Hi patriciadaley and welcome to the forum!
You didn't complete the editing on the events (sections). So for example, you edited an event by detecting transients. You edited some parts but moved on to other events to edit those. You never finalized the event. To finalize an edit such as an audio event, right click on it and select to bounce the selection. Then the track or event color will return.
Welcome to the forum!
Lokeyfly is right, you're in "Show Bend Markers" mode, that's why the audio events are black. However, Bounce is not the solution (there's no need to bounce and create redundant new audio files, and with bouncing you will loose the original event). You can just right-click the event and uncheck "Bend Markers". This will return to the "normal" mode with your regular colors...
Lukas Ruschitzka
Studio One Specialist Advanced Studio One Tutorials || Free Studio One Scripts || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ] Core i7 3.24 GHz, Windows 10, 24 GB RAM, RME HDSP 9632, PreSonus FaderPort, PreSonus Monitorstation, PreSonus Eris 5 Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate |
Thanks! It's the first time I've used the bend tool. I don't think I could have figured that out. Much appreciated!
jazzundso wroteWelcome to the forum! Ah, I didn't realize or I just forgot to uncheck bend marker, probably thinking the event didn't hold. Thx. As to bouncing though, one won't lose the original event ever, really. The event is a clip still in the audio pool. I'm never worried about too many clips as it's so easy to eventually remove all unused audio clips. That's a rather defining moment to be aware of, but I Save As to a new song, so there's never any old clip issue. Thank you for the uncheck reminder though!
Lokeyfly wroteAs to bouncing though, one won't lose the original event ever, really. The event is a clip still in the audio pool. The event is not the clip. Sure, you won't lose the clip (audio file). But in case you have applied any editing to the event (such as fades, volume change, EventFX) this will be baked in when bouncing so you lose these edits as parameter changes and can't modify these changes anymore (unless you start from scratch). That's what I meant when I said you lose the original event.
Lukas Ruschitzka
jazzundso wroteLokeyfly wroteAs to bouncing though, one won't lose the original event ever, really. The event is a clip still in the audio pool. I never said the event is the clip. I said the event is a clip. Meaning coming from or changing to more clips. The point is a history of finalized edits is accessible. Audio events at some point don't sit there with edits not printed (baked as you say). Sure, they can if that was someone's intent is not to do anything with the final result, such as stem, or solidify the resultant edit. Perhaps you work with a dozen or so partially edited audio events. I think its fair to say many if not more, dont, particularly with audio. With audio, many often tend to poop or get off the pot. (If I'm paraphrasing). I think your point is in-process edits, and that's probably fair to say. Though editing audio typically requires not having them sit and lay around half edited. They inevitably do get printed (bounced). To extend an olive branch. Sure, I probably should have said an event is from a clip. My bad.
Yea my definition of destructive editing is from the cubase days where you processed a fade in off line and you changed the original file.
When comping and you have a track with many pieces you need to bounce that to take it to melodyne but you could save a copy of all your edits if you think the editing has to be revisited. So Save a copy and bounce a copy. That's the only destructive part of bouncing is loosing your edits. I quit doing that because I never revisited any editing. Bouncing consolidates and replaces long files with relevant content. After bouncing to go into melodyne I bounce to get rid of the melodyne edits. I see an overhead with leaving them in the song as far as boot up time. I use it to print fx and use different patches from an instrument on one track. I do not think of bouncing as destructive myself.
Tacman7 wrote: "When comping and you have a track with many pieces you need to bounce that to take it to melodyne but you could save a copy of all your edits if you think the editing has to be revisited. So Save a copy and bounce a copy." Excellent alternative and something I do. I almost always save a copy of a comp, by dragging it to the back of the song. Then bounce the existing also edited comp in place. This serves two useful purposes. One, it preserves the edits of the original as you say. Two, it shows where you originally comped, so if you use that for example another verse. Drag it to the other verse, and you see what has already been used (lanes or parts promoted). Very useful. My wording should have been better, but that's not to suggest you can't return older clips. You can. To Jazzundso's point is if the event is undergoing edits, and you wanted to keep that progress going, you can right click and "uncheck bendmarkers" to get back the color of in this case, a transient detect. Tacman7 wrote: "Bouncing consolidates and replaces long files with relevant content." Couldn't say it any better, myself.
I'll take a stab and say that it appears they were events moved from another (or earlier named) track. They're different from the track names showing at left. That makes me think the origin or instrument is somehow missing. Ironically, that really shouldn't matter because the event properties would still sound even when moved from another track. Heck, I do it all the time. But it might be some indicator of perhaps the instrument you can no longer play?
Check your instrument list and make sure that all instruments you're looking for are available. The fact that the events are grayed out shows some false availability me thinks. The instrument list is when you open the mixer [F3] and look to the left and click on the Instruments button. . I'm guessing your "backing synth" and "kreamed lead for solo" instrument or patches are not turned on or available.
bobgood1 wrote Yes, sure. Your track colors are correct but your events on the track have the gray color. So you have to change the color of the event. That can be done by right-clicking on the event. You might find my video on track and event colors useful: @Lokeyfly: No, sorry, your wild guess is not correct. Event colors are not at all related to the instrument assigned to the track. Disabled tracks change their color and turn gray (but not the events) - that's the only case where the state of the track affects the color.
Lukas Ruschitzka
@ jazzundso: I see, the whole track would turn gray. I also see it seems to be not a sounding issue, but merely a color issue, so my bad again. . Yet bobgood1 states he can't change the gray. I see what you're saying, he likely just needs to right click on the event to simply change the color. Why don't I think people simply don't try that? 🤔 He must have some point performed an override of the event over track color.
My intention which slightly got skewed was I thought the event or instrument was gray due to some disengaged origin. The event is probably simply just gray from the probability of simply being gray. (Smile) Thanks for noting! Good call.
Lokeyfly wroteYet bobgood1 states he can't change the gray. I see what you're saying, he likely just needs to right click on the event to simply change the color. Why don't I think people simply don't try that? 🤔 Because I need reasons to do my videos.
Lukas Ruschitzka
jazzundso wroteLokeyfly wroteYet bobgood1 states he can't change the gray. I see what you're saying, he likely just needs to right click on the event to simply change the color. Why don't I think people simply don't try that? 🤔 Absolutely. I have to remind myself that some newcomers simply don't have (at least at their present state) a handle on how such things work. Hence, a good instructional video. Good job!
Users browsing this forum: No registered users and 50 guests
