arndkaiser wroteDarienGS wroteJust excitedly loaded up v5.4 on my M1 Mac for the first time, only to find that loads of my plugins are missing. It looks like x86 VSTs aren't being found, though AUs are. Any ideas, anyone? So my question is would it be better to run Studio One with VST's using Rosetta or run it with the M1 chip and use AU's? |
davidcarlyon wroteNow some of them have scanned but the vast majority just aren't showing up. Work fine under any other DAW I have. Ugh what a waste of time They're showing up fine in your other daws because they're running in Rosetta mode. You can right click on the Studio One app in the application folder and in 'Get Info' you can reset Studio One to use Rosetta mode as well... From what I understand, about the only plugins that work in native mode currently are the FabFilter bundle, and AU's, which someone mentioned earlier are actually just wrapped automatically in Rosetta. Not sure about the Presonus built in plugins. (Update: of my plugins, my Melda, Valhalla, and Tracktion Daw Essentials plugins are also m1 native compatible, as well as instruments from AAS and MODO Drum from IK Multimedia).
davidcarlyon wroteNow some of them have scanned but the vast majority just aren't showing up. Work fine under any other DAW I have. Ugh what a waste of time You'll have to right click on the Studio One app in the application folder, select get info, then select open in Rosetta. Otherwise use the AU version of the plugins while in M1 mode if they are available. That's if you want to run Studio One in M1 mode. |
Cinemascore wroteHi everyone, This is a rare case where the local built into S1 is slightly better. Both have a Content area, and both open each section to all the content. However, the local one is better at search. It highlights your search words in the results and makes it easy to find a specific question.
SPECS: Win 11 22H2, 18 Core i9: 32Gb DDR4 ram, 42" 4K monitor, StudioLive 24/16, Faderport16, Central Station Plus, Sceptre 6, Sceptre 8, Temblor T10, Eris 4.5, HP60, Studio One Pro latest, Test Platforms Reaper latest, Cakewalk latest |
- Potential crash when selecting Browser tabs When I read this in the bug fixes section I thought my problem was also solved. But it still happens. When I select "Files" section in the browser which has my "Drum Kits" folder in it, Studio One freezes for 30-40 seconds, then opens the Drum Kits folder inside Files. At first, I thought it was because of my drive (SSD), and checked it manually, when I open Drum Kits folder in Windows Explorer it opens up instantly without freezing or waiting, same for FL. But in Studio One it just freezes for 30 seconds, it really kills the workflow. I created a ticket last week they said they know the issue and it will be fixed, and today support sent me a message that they solved this in 5.4 but as it can be seen from the notes, it solves the crashing not freezing. I don't have a crash, it just freezes without crashing. Anyone else experienced the same problem? I'm waiting for support's reply right now.
Using Studio One 6 (Always the latest version)
System i9 9900K, 64GB RAM, 2080TI, 34" 4K Display & 55" 4K Professional Display, Windows 10 Studio I/O Lewitt LCT-440, Yamaha HS7, PreSonus Studio 1824c, Beyerdynamics DT1990, Audio Technica M50X Studio Gear Arturia Keylab 88 MK2, Atom Pad, Atom SQ Instruments Cordoba GK Studio, Takamine GJ72CE, Godin Session, Yamaha F310 R&B Singer / Songwriter / Producer Website |
Oh my gosh....the Plug In Nap feature is brilliant. I can now open a session that brought my PC to it's knees. (65 tracks with TONS of VSTs and VSTis...full orchestration, etc.) Now, the Performance meter barely is 1/3 full. It's crazy. Before, the session would actually crash when I tried to play it. Works flawlessly now.
graytermedia wrotePush wroteWhat this mean ? Somebody knows ? Go here https://s1scripts.wixsite.com/colortoolbar Follow the instructions. Works like a champ. Changes were made in Java that no longer supports the old version.
Got really excited about native M1 support, then soon realized the native plug-in requirement. With the requirement to have all my plugins compatible, I can't foresee myself being able to use the feature any time soon.
About the AU wrapper mentioned earlier. What I read about the subject, it seems that people have found the AU Rosetta bridge (provided by Apple) to be buggy. I'm also under the impression that AU does not support side chains? Is it too much to hope that Presonus and/or Steinberg would be working on a VST Rosetta bridge? |
Yes, "Track Colors v1" no longer works as of Studio One 5.4 and needs to be deleted from the Scripts folder.
"Color Toolbar v3" is the replacement and adds a bunch of new features that support "One Click" Color Channels, Tracks, Events, Arranger Sections & Assign Icons" for Studio One. Color Toolbar 3 Website: https://s1scripts.wixsite.com/colortoolbar
Is there a way to disable Plug-in Nap for specific plugins?
PC: AMD Ryzen 3900X, 32GB RAM DDR4 3600MHz CL16, ASUS ROG Strix X570-F, Gigabyte Radeon RX 570 8GB, SSD CORSAIR SSD MP510 960GB M.2 NVMe (OS)
OS: Windows 10 Pro x64 DAW: Studio One Professional x64 Gear: RME Fireface 802 + RME Advanced Remote, Prometheus Acoustics monitors, Avantone Mixcubes, JBL 305p, Softube Console 1, Presonus Faderport, AKAI Advance 61, Presonus Faderport, Beyerdynamic DT-990 Pro |
M1 customers if you have not already found.
https://support.presonus.com/hc/en-us/a ... d-to-know- https://support.presonus.com/hc/en-us/a ... setta-mode
Some great new stuff in 5.4 but I have to roll back I think, it now has a big problem with Acustica Nebula which is kind of a mainstay in my work. Thing is I don't know how to roll back if the 5.3 installer is no longer there. Does anyone know this?
EDIT: As I raised a ticket with Acustica for this I'd rather not roll back but wait for a solution. Plus rolling back makes me nervous (I was daft enough to upgrade mid-project). I found a workaround for the problem anyway using a plugin wrapper. I would still be curious what the rollback procedure is though if the installer isnt there. As I said, some great new features. Not only the Nap but the ability to mixdown multiple formats will be a timesaver for me. |
drewcampbell5 wroteSome great new stuff in 5.4 but I have to roll back I think, it now has a big problem with Acustica Nebula which is kind of a mainstay in my work. Thing is I don't know how to roll back if the 5.3 installer is no longer there. Does anyone know this? You should be able to go to your account, find previous versions and just download that. I am unaware of any neat tricks to simply roll back. |
Users browsing this forum: musicchamber, patm300e, strumpy_strudel, Trucky and 68 guests
