Simple question, can make the title bar of S1 (in Windows) green, or whatever color, but not the line below it Which lists File Edit Song Track Etc...
I want to get rid of this white color and maybe have something dark there. Any way to do it you know of? (SEE PICTURE)
Screenshot S1 (351).jpg (7.36 KiB) Viewed 336 times
computer1:
ASUS ROG GL702ZC
AMD Ryzen 7 1700 (8/16 cores)
32 GB RAM
Studio One Artist 5.2 May 2021
USB ARRAY 4 ports:
1 C: M Track 8x4 interface (Default for S1) MIDI i/o is System 1m;
2 A: FTU8R MIDI in fr P10 out
3 A: 4 hub, -Presonus AB96 MIDI fr P10 thru, -Cam, -MPK MINI, -Xk25
4 A: 7 hub -MsftLCamStudio, -PSATOM, -Xk37, -Pr10, -ABSPro, +2 idle
Network:
NDI, Mouse, MIDI
computer 2:
Razer 4/8 i7 7700 32RAM
USB ARRAY 4 ports:
1 TB: 4 hub: -Xk25, -??, -MsftLCam3000
2 A: -FTU8R MIDI i/o BSP
3 A: 4 hub: -MseKbd, -SDXL -JP08, -Mk3
4 A -FTU MIDI in is Oxygen 8 v2
by Trucky on Sat Jun 12, 2021 9:49 pm
I'm not aware of an option in Studio One to change that but you can use High Contrast mode in Windows 10 to achieve this.
https://www.tenforums.com/tutorials/131111-turn-off-high-contrast-mode-windows-10-a.html
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account.
Windows 11 Pro 64-bit (21H2), Studio One 5.4 Pro | Notion 6.8.1 | Universal Control v3.6.0.66460
Series III 32 v2.5.17953, Revelator io24 v1.13
by jebbyslonar on Sat Jun 12, 2021 10:02 pm
What is this some sort of protected slot of the greater 'Operating System'? I have several programs that change the look and whatnot in windows but this Titlebar is always white in Studio One. Can set Title bar at an accent color or perhaps just plain black in windows. Wouldn't recommed the aging long "Windows/Resources/Themes titlebar workaround at intowindows.com, it takes a few minutes and makes everything into the default that you get when you first get a new computer. Not great. The
Step 1: Navigate to Settings > Personalization > Colors. Scroll down the page to see Show accent color on the following surfaces option.
Step 2: Select Title bars and window borders checkbox. That’ts it! From now onwards, title bar will use the same color as the current accent color.
Step 3: To change the color, on the same page, either click on of the color tiles or click the Custom option to create a color of your choice.
also doesn't work. I select to pick a accent color from my background which is currently just black, and instead of changing my file View Studio One Help bar to gray, it changes the top line bar (title bar) which was set as green in S1, to gray, and then leaves the white.
Terrible. The results are just terrible. All it did was take away what I had already set up in S1's options, which I didn't even expect that it could even do!
:o :reading:
not fond of the option high contrast mode. It seems to make things really blocky.
I did manage to get the color to change but I had to use stardock Windows Blinds to do so..
computer1:
ASUS ROG GL702ZC
32 GB RAM
USB ARRAY 4 ports:
Network:
NDI, Mouse, MIDI
computer 2:
USB ARRAY 4 ports:
by Trucky on Sat Jun 12, 2021 10:37 pm
Glad you found a solution that works for you.
