Hello
I am in the process of transferring my Revelator from it's current PC to a new one - and want to know if all the changes I see the main Revelator panel (that pops up when clicked in Univ Control) is saved somewhere on the PC or can I simply setup Universal Control on the new PC - plug in the Revelator and the settings come with it? Appreciate any info on this. Cheers VP
The defaults are included when you install UC and select the PreSonus DSP USB Series Driver.
Any custom settings you've made are stored here:
Trucky wroteThe defaults are included when you install UC and select the PreSonus DSP USB Series Driver. Trucky Thanks for the update - however - I cannot see anyway to actually make a settings backup via the Revelator interface AND - I do not even see that folder you are referencing. But I can tell you that I have made a number of changes to the Rev layout and would like to be able to recreate that exactly on the new machine. Appreciate any other info you can share. Cheers! VP
What version of Universal Control are you running?
Trucky wroteWhat version of Universal Control are you running? Latest - 3.4.2.63992 But this unit was installed using 3.4.0.xxxx when first installed back on Christmas Day. VP
Check the "Storing New Presets" section in Chapter 4 of the manual:
https://pae-web.presonusmusic.com/downloads/products/pdf/Revelator_Owners_Manual_EN_11032021.pdf
