My problem is simple. Im on "Channel" mode, I can freely select the first 11 tracks, everything works perfectly there. If I press next when on channel 11, nothing happens. If I select channel 12, the fader does not respond, and if I touch the fader, it will jump back to which ever fader the Faderport thinks its on (whichever was chosen last with the Faderport). I have updated the firmware, everything is set up according to the manual, it has been booted into Cubase mode, its setup as a device in Cubase, I checked the blinker fluid etc. etc. Nothing seems to let me get past channel 11.
Now I know, Mackie MCU is an 8 track protocol. So going past track 8 should load in the next bank of 8 tracks, which makes sense and is correct according to this post from Presonus:
https://support.presonus.com/hc/en-us/a ... Navigation
However, that is clearly not the case.
Anyone have a solution? Is this a problem introduced with Cubase 11? Will a fix be posted? Any ideas?
Thanks everyone, this is driving me insane
Ari
Cubase 11
Ryzen 1700X 8c/16t @4.00 GHz, 32 GB RAM, RTX 2700S
2 NVME drives, 3 SSD drives, 4 HDDs
Focusrite Clarett 4Pre USB,
Roland FA-08 Keyboard || Roland TD-12 Digital Drums
Presonus Faderport, Nektar Panorama P1, Arturia Keylab 61 Essential
by klypeman on Sat Feb 13, 2021 5:58 pm
Are your shift button by any chance lit ?
AMD Ryzen 7 3800X 8-Core 3.90 GHz Windows 10 64bit Home, MacBook Pro + Mini Big Sur, SO 5.5 Pro, SO 6.1.1 Pro, LUNA, Cubase 10.5 Pro, SLIII32, 24.4.2, 16.0.2 FW, Quantum 2626, Faderport 8, FaderPort 16, Atom, Atom SQ, Console 1+Fader 1, UA Apollo Twin TB/USB, Toontrack, NI Komplete 12, ++
by arianagonzalez1 on Sun Feb 14, 2021 10:34 pm
No, shift light definitely isnt lit
Cubase 11
by klypeman on Thu Feb 18, 2021 7:40 pm
I will look up this in 10.5 Pro but have had problems getting past the first 8.
Am mostly on SO 5..
by klypeman on Fri Feb 19, 2021 7:09 am
I found out that if I press the Number under the channel I want to go to and Next on the FP2018 it switch to that channel all I had to do was to move the motorized fader on my FP2018.
Also I had to get rid of a second Mackie Control that I used on another controller but that's another story.
Hope it helps
