Hi! (sorry my english) When i conect a Sennheiser dynamic mic or a shure sm57 on the channel 1 or 2, i have to raise up the knob almost to the max to get some volume. Maybe am i doing something wrong ? or is it just the interface?
greetings
bye!
by Trucky on Sun Nov 08, 2020 2:59 pm
It shouldn't be a problem. Please post your system specs.
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account.
Windows 10 Pro 64-bit (20H2), Studio One 5.1.2 Pro | Notion 6.8 | Universal Control v3.4.0.61835
StudioLive Series III 32 v2.4.17466
by gustavomartinez13 on Sun Nov 08, 2020 4:51 pm
thanks for the answer
windows 8.1 64 bits
8gb ram
core I5
by Trucky on Sun Nov 08, 2020 6:30 pm
The latest version of Universal Control (v3.3.0.59348) for Studio 68 requires Windows 10 v1709 or later.
UC v3.3.0.59348 Release Notes:
https://pae-web.presonusmusic.com/downloads/products/release_notes/UC_v3_3_Milestone_Release_Notes.pdf
by gustavomartinez13 on Mon Nov 09, 2020 12:33 pm
Trucky wroteThe latest version of Universal Control (v3.3.0.59348) for Studio 68 requires Windows 10 v1709 or later.
So i have to buy windows 10 to solve this problem?
there is not other solution?
PD: From presonus replied me :
Thank you for the system file. It shows that your Studio 68 appears as connected and installed properly.
Dynamic mics require more power to get a decent level and are less sensitive than condenser mics.
We suggest testing with a condenser mic to get more head room.
by Trucky on Mon Nov 09, 2020 1:17 pm
SOLVED - Their response is correct regarding Dynamic and Condenser mics.
You just need to update to a supported Windows version if you'd like to use current versions of Universal Control.
by SwitchBack on Mon Nov 09, 2020 1:25 pm
Download UC for your version of Windows. During installation it will show a list of interfaces it has a driver for. If your interface is there then you should be fine.
Dynamic mics are typically used for high SPL instruments (brass, kick, ...) or very close range, think 2” or less (solo vocal, ...). Anything less loud or longer range you probably want a condenser mic for better output levels.
by gustavomartinez13 on Mon Nov 09, 2020 1:28 pm
SwitchBack wroteDownload UC for your version of Windows. During installation it will show a list of interfaces it has a driver for. If your interface is there then you should be fine.
Dynamic mics are typically used for high SPL instruments (brass, kick, ...) or very close range, think 2” or less (solo vocal, ...). Anything less loud or longer range you probably want a condenser mic for a better output level.
yes , i installed the UC windows 8 version
And about the dynamics mics, thanks, now i get it. :punk: :D
