here is a vid of the issue.
https://www.youtube.com/watch?v=Wgzxja0ghPE
Sometime you need to do a refresh. On the bottom right on the S1 screen, click on Browse, then on home icon upper right and you will see a reindex button at the bottom.
Reminds me of a Hollies song, On a Carousel, Up Down Up Down ......... Anyways back to it ...... I assume you got it to save though, at least went through the motions? You can right click on a preset as well and you should see a "show in explorer".
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR, Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC. |
WaterlooSunset wroteSometime you need to do a refresh. On the bottom right on the S1 screen, click on Browse, then on home icon upper right and you will see a reindex button at the bottom. Thanks for the reply. That didn't work though. It's weird. I can't get this song to save as a template either.I got a perfect drums note map to save one time. Then I tried making a different map and that wouldn't save. Now this SD3 map wont save either. I guess Im religated to always having some sort of issue. I constantly have issues of one sort or another. I just switched to studio one from Reaper because I could not get it to stop crashing. I had a mac and then built two different PC's and all 3 crashed. I even got a new interface. Still didn't work. So I switched to S1 and its been running great except now these two problems pop up. |
Here are screen shots for my SD3 Drum Maps thru Studio One 4.X:
Here's a link to another topic that might help you: viewtopic.php?f=151&t=33304 |
Bbd wroteHere are screen shots for my SD3 Drum Maps thru Studio One 4.X: Mine wont show up in the drop-down menu like that. Its really odd. I got my perfect drums map to show up one time and then it disappeared. Now I am having this issue. I contacted support. |
johnboyd4 wroteBbd wroteHere are screen shots for my SD3 Drum Maps thru Studio One 4.X: Here is a vid of the issue. https://www.youtube.com/watch?v=Wgzxja0ghPE |
If none of this works, well..................... No idea, try on another machine to just see it work......
All i can say, this was an issue with me in 3.x something. I have not created any maps in a long while. I had to re-index every time. Verify you did re-index presets? Also, my GM map is under the programs folder. C:\Program Files\PreSonus\Studio One 4\Presets\User Presets\Pitch Names My self created ones are under the Data folders. E:\Studio One\Songs V4\Presets\User Presets\Pitch Names
johnboyd4 wroteOk, well thx anyway guys. I watched your video. Your preset path in Explorer is not the same as mine. Please review the screen shot I sent and compare to your S1 setup for presets. |
Hey Guys,
I just checked my main S1 PC. This is a new rebuild of OS from scratch last year so it is still pretty pristine IMHO.Also moved from win8.1 to Win 10 and a larger SSD for C drive. There are 2 paths at play here. The only default pitchlist is GM which in on my C drive under this path. C:\Program Files\PreSonus\Studio One 4\Presets\User Presets\Pitch Names My user created preset is save to this path, which is under where S1 points to to save songs/data. F:\Studio One V4\Presets\User Presets\Pitch Names I am curious if the OP looks in that place. His vid showed the default path for the single GM pitchlist. I wonder if it is saving, just not showing up, (re-index). Thnaks
Users browsing this forum: No registered users and 88 guests
