I'm trying to create my own ruleset for VSL cube. I choosed to work with Vienna Ensemble (externaly loaded) which will contain all the orchestra instruments (because Notion crashs too often when loading high number of VST). Then in Notion, I create external midi instruments (violins, cellos, etc.), sending to Vienna Ensemble with LoopMidi (four ports of 16 channels). The beginning of the rules creations started well, but I can't find how to create Midi Techniques (pizz, etc.). I understand that one can make presets for instruments, but as I'm working with External midi I don't know how to do that (there is no instrument in Notion in this case, only midi...) ? Is someone know how to do this ? Thanksfully, Terry |
Hi again,
I found how to have new techniques with presets files. I've created a preset XML, and an instrument file with new personnal techniques. However, in the instrument file, I didn't use a VST instrument but an external midi. The instrument file works fine. But if I recall the VST preset in a new Notion score, if everything seems fine (new techniques, layout, etc.), there is no external midi anymore. So this is not working for me and I really wonder why... Can anyone help me ? Thanks Terry |
I'm not sure why you are using the external midi send. You can send directly to Vienna Ensemble as a Notion instrument. You just have to create a separate staff for it. See my tutorial here (it's a bit old but still applies for the most part):
Let me know if you have any questions!
Hi, and thanks a lot for your answer.
I looked carefully at your tutorials and yes, it's working now, thanks a lot ! However, I discovered that the parts names change after the instrument change. So except for the first page, I lose all parts names afterwards (it's written VSL Ensemble everywhere...very confusing when composing). Is it possible to correct this behaviour ? Thanks a lot again ! |
Karmasutra69 wroteThanks a lot again ! Happy to help!
