I just hooked up a pair of Eris 5 speakers to my home audio system; they're connected to a Focusrite 2i2 interface. I notice that there's a very soft, kind of "rustling" sound coming out of the speakers at all times. It isn't affected by the gain control on the interface. I do note, however, that it's affected by my simply scrolling on my computer screen, either on a document or on the web. Any idea why this is happening? Suggestions??
Hey Dan
I have had similar in the past, turned out to the wires being to close to my old monitor - happened becaue of lack of shielding I would try to move the wires away from the monitor or power sourse as a first It's worth a try Ch33rs Saga
Studio One v2.x 3.x 4.x-
- Firestudio Modile - M-Audio BX8 D2 Monitors A few VST's and VST-I's Korg Krome and a few yamaha's Windows 7 Ultimate 64Bit sp1 on MB: Asus F1a75-V Pro with AMD Athlon II x4 651 (3.0Ghz) and 8gigs RAM Graphic: Radeon HD5770 To add your software and hardware specs to your signature to make it easier for us to help you, click HERE. ![]() |
I have the same problem as Dan. And since my rack is built into my desk right under my computer monitor, I really don't have the option of moving the cables out of the way so I actually bought a couple of Hosa cables that are supposedly shielded for EMI and RFI rejection, but I still get noise from the monitors when scrolling on the computer.
Does anyone know of any good shielded cables that can stop this? |
Before buying new cables, do some troubleshooting to make sure they are the issue.
If you move them away from the monitors does the noise change in any way? Turn the output of the AudioBox all the way to zero. Is the rustling noise still there? Unplug the inputs to the speakers. Is the noise still there?
MacBook Pro 2 GHz Intel Core i7 with 16GB RAM & OS 10.9.5. Studio One Professional 3.5, Notion 5, 2x PreSonus Firestudio Project Interfaces, PreSonus ACP88, PreSonus Sceptre S6, FaderPort, Melodyne Editor 2.1.2, Waves Gold Bundle 9, Nomad Factory Integral Studio Pack, Native Instruments Kore 2 & Komplete 6 (Kontakt 5), IK Amplitube 3, AAS String Studio & Ultra-Analog VA2. Faber-Castell #2 Pencil
Lol I have the same issue right now.
Eris E5's connected on my PC by a premium mini headphone to RCA cable to my Xfi sound card. I hear it more while scrolling a page on my screen just like you. Not sure what the issue is yet, but If I just plug it into my phone and play back audio with same cable, same place, I get no interference at all. So it's something between my PC to the speakers. Hmm... I just bought a line conditioner/power strip so hopefully that will clean up everything. We'll see. Let me know if you figure it out as well! ![]() |
You may be getting noise from the cabling also. Studio monitors are meant to be connected via balanced cable. The longer the cable in your setup, the more chance for noise also.
Just something to look out for when troubleshooting. |
Resurrecting this thread.....
I also have a rustling sound in one of my Eris 5 monitors and it has become distractingly loud. How did you guys fix this issue? I really don't want to spend $70 plus shipping to send this in to PreSonus, and I'm going to be really frustrated if I'm expected to pay for a faulty part after only a couple years of light use. ![]() Help??? |
I have just replaced my M-Audio AV40s with Eris E5s and I am also getting this noise.
The noise is the same level whether the output on my Steinberg UR242 is turned to zero or turned up. I am using the same cabling as on my previous setup, 1/4 inch to 1/4 inch TRS, as my audio interface doesn't have XLR outputs. I wondered if having the other inputs on the speakers not connected to anything was allowing them to pick up interference. Any thoughts? |
Ok, I checked my cables and realised I was using unbalanced ones to connect from my audio interface to the speakers.
![]() I have now purchased some of these --> https://www.amazon.co.uk/HosaTech-STX-1 ... h+STX-110M and the noise has gone. ![]() |
I use TRS cables going from the interface monitors out going into the Temblor T10 inputs and XLR cables going from the Eris E5s inputs to the T10 outputs with the T10 ground switch in the Ground position. No hiss or hum at all. I recommend a power conditioner or a surge protector with efi and rmi protection
Presonus Audiobox USB
Presonus Studio1810 presonus Atom StudioLive CS18AI Presonus SW5E Studio one artist Studio one 4 Professional Behringer BCF2000 Reason 10 M Audio Keyrig49 M Audio AV40 Presonus Eris E5 Presonus Temblor T10 Akai XR20 CAD Audio GXL 2200 Shure SRH 840 EX 29 Extreme Isolation OS Windows 10 24Gb Ram Amd 8320 Sapphire RX 580 Nitro + |
I'm still amazed at the sound stage provide by the Eris 5.
The E5s are hooked up to my audio interface via balanced cables with XLR connectors. The cables are low-end (cheap ![]() |
I'm having the exact same issue. I have VERY loud humming and crackling that has been narrowed down to being RF interference. Sadly the only thing that helps a little is wrapping them in tinfoil but that doesn't full get rid of it and it's quite an eye sore. I wish PreSonus would insulate these better, they're great monitors but the RF noise makes them almost unusable
