185 postsPage 6 of 10
1 ... 3, 4, 5, 6, 7, 8, 9, 10
The tweed wroteHi Lawrence,
Is there a possibility to group colors not only by 5 between separators?
Found It! Have a good day, everyone!
-- The Tweed Band: https://www.fb.com/Tweed.Is
by dimalesyk on Sat Sep 07, 2019 10:38 pm
May you tell how to make?
by tripsmarcel on Tue Nov 05, 2019 8:40 pm
Lawrence wroteHere's a toolbar add-on that allows you to create, store, import and export custom color sets of 40 colors using any RGB colors to color tracks or events.
THANK YOU THANK YOU THANK YOU!!!!
by jcrakes on Sun Nov 10, 2019 7:02 pm
I downloaded the package a few months ago and it showed up in Studio One 3. For some reason, it's not showing up in the latest version of SO1 4 after installation attempt.
Go figure. Redownloaded from original thread and reinstalled numerous times without success..
Any ideas?
Thanks!
S1 4.6
Win 10
16 GB RAM, i5, 3.2G
Babyface Pro interface, Faderport classic, Console 1
Guitars, amps, keyboards, etc.
by Jemusic on Mon Nov 11, 2019 12:25 am
I have just checked this and it is all OK. Download the package, put it inside your scripts folder (inside the Presonus folder) Reboot Studio One and it should all be there.
Note when you update Studio One, these extra scripts can get wiped out for some reason and they revert back to the install scripts. After an update you may need to put them back in.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro
by jcrakes on Mon Nov 11, 2019 4:53 pm
Thanks for the reply... When I tried to install, I had already updated Studio One to the latest build. I will try to install the package again to see if anything has changed. I would like to avoid reinstalling S1 if possible, but I guess I could if need be. Though it originally installed correctly in S1 3.5, now it doesn't work in S1 3 or 4...
Fingers crossed...
Salud!
S1 4.6
Win 10
16 GB RAM, i5, 3.2G
by jcrakes on Tue Nov 12, 2019 9:48 am
no luck.. maybe an s1 reinstall will do the trick
S1 4.6
Win 10
16 GB RAM, i5, 3.2G
by jcrakes on Tue Nov 12, 2019 6:25 pm
reinstalled s1--no luck with the package... about to throw in the towel :(
S1 4.6
Win 10
16 GB RAM, i5, 3.2G
by BezowinZ on Wed Nov 13, 2019 12:38 am
Being new to S1, I’m a bit confused. These won’t work on non-instrument/audio tracks in the console? Will these work on the multi-output tracks from a drum VI, for example? Busses, FX, etc?
Studio One 4.6.2 Pro, Mac OS 10.14.6 (3.6GHz 8-Core i9, 64GB RAM, iMac / 2.8GHz 4-Core i7, 16GB, RAM MBP), Clarett 8Pre Thunderbolt, MOTU MIDI ExpressXT
Presonus, I’m still human! Please find a better security method, please.
And where's my avatar?!?
by Jemusic on Wed Nov 13, 2019 1:10 am
BezowinZ wroteBeing new to S1, I’m a bit confused. These won’t work on non-instrument/audio tracks in the console? Will these work on the multi-output tracks from a drum VI, for example? Busses, FX, etc?
While you in the arrange window you can simply apply these colours from this package to the tracks. All the tracks in the mixer will reflect the changes made in arrange. Colouring multiple outputs from a single VST in the mixer view only seems only possible using the normal colour palette.
by wongothesane on Wed Nov 13, 2019 4:02 am
In case anyone is interested, I've made a custom color set, spreading the colors around the color circle (45° increments) and, for each color, starting with 50% brightness and 100% saturation, then 75% B 100% S, 100% of each, 100% B 75% S and finally 100% B 50% S. Here is the result:
If you want to use it, simply copy the text below and paste it in a text file somewhere on your computer; then, in S1, open Lawrence's color bar, select "Import hex colors" in the menu and point it to that text file. Done!
* 0°
800000
bf0000
ff0000
ff4040
ff8080
* 45°
806000
bf8f00
ffbf00
ffcf40
ffdf80
* 90°
408000
60bf00
80ff00
9fff40
bfff80
* 135°
008020
00bf30
00ff40
40ff70
80ff9f
* 180°
008080
00bfbf
00ffff
40ffff
80ffff
* 225°
002080
0030bf
0040ff
4070ff
809fff
* 270°
400080
6000bf
8000ff
9f40ff
bf80ff
* 315°
800060
bf008f
ff00bf
ff40cf
ff80df
Studio One - Reason Suite - RME Babyface Pro - Windows 10 - 32 Gb RAM - i7 6700K 8 cores @ 4 GHz - 3 SSDs - 3 monitors (2560x1440, 1920x1200, 1200x1920)
by garyshepherd on Wed Nov 13, 2019 9:43 am
Nice - thanks
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Mojave OS 10.14.6, 64 bit, Studio One 5 Professional (always the latest) , Reason 11, Melodyne 5 Editor, Digital Performer 10, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 1.93, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Alesis Q49, Audient iD14, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
by BezowinZ on Sun Nov 17, 2019 2:36 pm
Damn. I want my related outputs the same color as my instrument & bus tracks. I’ll stick with the default options for now.
Not sure what I did differently, but too many of my track colors look too similar. I thought it was the dark background, but it looks much better in vids with the same dark background.
by andies1966 on Tue Nov 19, 2019 1:35 am
Very Cool. Thank you Lawrence for the track colors.
by MarkusHassold on Wed Nov 20, 2019 2:49 pm
How could I miss this for half a year?
That is way cool, Lawrence!
Thank you so much!
- Mac Mini 6.2, (2014), internal SSD+HD, 2,3 GHz Core i7 quad, 16 GB RAM, MacOS 10.14.6 Mojave with Presonus Firestudio Tube, Firestudio Project with Universal Control 1.7.6,
Presonus Faderport8, Atom, Bluetube DP, HP 4, Bluemax.....
- iMac 27" 3,4 GHz Core i5 quad, 1TB Fusion-Drive, 40 GB RAM, MacOS 10.15.5 Catalina with Presonus Studio26C
External harddiscs (3.5" - 7200 rpm) USB 3.0
Presonus Studio One Pro 5.0.1
Celemony Melodyne Studio 5
Softube Console1 MK II (Console1 Version 2.4.99)
by Mac Money on Sun Jan 05, 2020 9:15 pm
MarkusHassold wroteHow could I miss this for half a year?
Thank you so much!
Same here!
Thanks so much Lawrence!
George Ware
StudioOne v5.0.2 Pro 64bit
Waves SoundGrid Studio 2
Waves DigiGrid IOS
Waves DigiGrid IOX
Waves SoundGrid Server One
PreSonus CS18ai & BCR2000 Control Surface
Intel 6 Core i7 3.2Ghz.
Windows 10 Professional 64bit. v1909
Arturia KeyLab-88 Essential
URS, Waves (Everything), EMI, Sonnox Oxford (Everything), Antares Unlimited, Plugin Alliance (Everything), Nomad Factory,TL Labs, Massey, Komplete Ultimate 12 CE, Arturia (Everything), Korg Collection, UVI Falcon, Audio Damage, Melodyne Studio 4.4.2, VocAlign, Eventide (Everything), Softube and IKM Total Studio Max.
As of 17 Sept 20
by Sostene on Mon Jan 06, 2020 7:27 am
Hi
How do i make my own set of color to import into the script?
I saw an TXT example file, tried to import it , but :-(
I then exported the default color set to see it's content, but i rally don t understand the color code inside that file.
-10079488
-6730752
-32768
-19866
I can clearly see they are 40 color codes , but can t understand each of them.
IMPORT HEX COLOR : how to do this? what is the type of the data to be imported? A css file or what?
A complete HOW TO will be great!
Thanks
by miked7 on Mon Jan 06, 2020 7:44 am
They cover this pretty well on page 2 of the thread. User Trucky posted some sights which explain the color numbers pretty well too, especially this one: https://www.rapidtables.com/web/color/RGB_Color.html
Mike Derrick | Studio One Professional 4.6, Win10 Pro 64, Intel Core i3, 8GB RAM, 1TB SSD, Focusrite 2i4
BandCamp
SoundCloud
by ansolas on Tue Jan 07, 2020 8:14 am
Is there a way to colorize the Mixer channels without adding them to the arrange window?
for example Single outs of Impact ?
StudioOne, FaderPort Classic, FaderPort 16, Windows 10, Samsung C49RG94SSU (5120x1440),
I7-4770k, ASUS Gryphon z87, 32 GB RAM, Sapphire RX580 Nitro + , 8GB RAM, RME Multiface II
__
macOS Mojave Apple iMac 27-Inch "Core i7" 3.5 (Late 2013) , (yes it supports Metal)
https://ansolas.de
by artjohnson on Tue Jan 07, 2020 11:15 am
Formidable workaround! Thanks. Could use a "saturation" slider to complete the effort.
Users browsing this forum: patricemazmanian, simonesant and 21 guests
