After spending the weekend trying to figure out why I got no signal in capture (Mojave permissions issue) which was solved, I now have a playback problem.
Running Series III 24R with Capture 3 (both up to date) into MBP Mojave 10.14.6. After recording a track into Capture, I hit the digital return to listen to the playback and get a god-awful, loud, obnoxious screeching noise with no sign of any of my recording. To be sure, I bounced the track to a wav file and played it externally and it was fine. Any help? |
Sounds like a digital feedback loop. It's different from typical acoustic feedback in Live sound, it's much worse actually.
Not sure where you are going wrong, but an example of digital feed back would be plugging the output of AUX1 into the input of channel 1 and then sending channel 1 (plus another mic channel) to AUX1 in mixer. It can take the most subtle noise from the mic and basically multiply it by infinity (back and forth from aux1 to mic1) causing a terrible noise. The same problem can be caused by going into the computer and back to the mixer in a loop also. Steve
StudioLive RM32AI
Problem solved - Switchback had it correct - the track I recorded was still armed when playing back. You'd think it would be a no-brainer to either tell the user (via the manual) to dis-arm the track(s) during playback or automatically do so when playback is initiated. In any event, the help is much appreciated!
Thanks for this. Been a long time user of StudioLive 16.4.2 and Capture 2. Breaking in a StudioLive 16R series iii and Capture 3 and this had me stumped. Was thinking I might have to use my old board for my next gig, but sure enough, the tracks were still armed.
I agree, it seems to make sense to me at least that if you push the digital return button that all the tracks should unarmed as well. I could see myself forgetting on a gig during sound check and making some people really unhappy. |
