Discuss Notion for iPad and iPhone here.
Hello all,
Notion for iOS is constantly crashing during playback, usually after a few seconds. The app is up to date, as is my iOS for my iPad Air 2.
I get the 14-16 instruments warning upon opening a score but this never used to be a problem (for many years). Now, even when I mute intstruments or "solo" 5 instruments in the mixer (i.e. strings), the playback crashes the app. I also have reverb and distortions turned OFF in the mixer.
Any ideas?
Have tried a hard reset of the tablet to no avail.
by michaelrohac on Tue Aug 20, 2019 1:04 am
An update for anyone else having this problem ...
I went through all the troubleshooting FAQs and found a solution ... redownload ALL installed sounds. Time consuming but solved the problem completely, no crashes or sound distortion since then.
by coolkiu00 on Thu Sep 05, 2019 8:28 pm
Oh, I am making the same mistake as you, really a headache!
Thanks for your post.
street view
by smithclarkson on Tue Sep 10, 2019 1:40 pm
Same ...
by ishikakhanna on Sat Sep 14, 2019 1:27 pm
Having the same issue.. It starts working for few days... after then i got it back
by jhonpacker on Fri Sep 20, 2019 12:59 am
You can sometimes fix the problem by forcing the app to refresh its data from the cloud or the app's original files, rather than the local storage. To perform a basic cache refresh, clear an app from your phone's recent memory. Your device keeps recently-used apps active, which maintains their local caches. See here is how:
    charge your phone at maximum capacity; ...
    turn off the device if it is still turned on by pressing and holding the power button; ...
    press and hold the volume up, home, and power buttons until the recovery menu appears; ...
    select "Wipe Data/Factory Reset"; ...
    press the power buttons; ...
    select "Yes delete all user data";
:thumbup:
visit: thevideo.me/pair error
by erinbloke1 on Wed Oct 16, 2019 4:59 pm
Had the same issue...and was having it with iTunes as well
