I read a few other comments about problems with Tripleplay. I contacted Fishman support several days ago but they haven't gotten back to me and maybe won't.
When recording with Tripleplay as a vst, the cursor stops and goes rather than moving at a constant rate across the track. Same thing when I play back the tracks. When I loop the playback, the stop and go is not always in the same place. When I send to Notion, and play it there, it's out of time. I hear the note play before it should. If anyone has found a solution to this, please let me know. What I'm using: 2.2GHz Intel Core i7-8750H 6-core processor and 16GB of DDR4 RAM 1T SSD Studio One 4.5 Pro PreSonus Studio 68 interface Fishman Tripleplay East West Midi Guitar Series - Orchestra |
What's the cpu usage showing in S1?
I can't see how a midi input could be changing the playback speed unless it's overloading the cpu and having a tough time keeping up. Can it be set to not send out bend messages? I've seen those give a computer some trouble. Try a real low demand vst in a new (empty) song just to see what's going on.
How does the controller install. (software driver I mean) Is there some form of USB driver to make the computer see it as a controller etc.
Have you set up your external devices correctly with it as a controller keyboard etc.. Looks a very interesting and cool guitar controller.
Tacman7 wroteWhat's the cpu usage showing in S1? CPU barely shows anything. This only happens when using Tripleplay on my guitar. If I use the very same East West instrument on my keyboard, everything works fine. I send it to Notion, and that works fine too. |
Jemusic wroteHow does the controller install. (software driver I mean) Is there some form of USB driver to make the computer see it as a controller etc. Yes, there is a usb drive that you use with Tripleplay. It's a wireless controller that communicates with the unit on the guitar. |
What other USB devices are you running. Maybe they are conflicting or interfering with the USB receiver in some way. Try turning your normal WiFi off perhaps and see what happens.
I can't solve your problem but I can empathise with it.
I had all manner of problems with my Fishman on two PCs and with three different DAWs. Some of the problems were similar to yours. I think it was mainly the USB drivers that caused the problem but it's hard to prove. Ultimately I returned it for a refund. Now I use a purely software solution - Jam Origin MIDI Guitar. I was sceptical that a software solution could work well enough but it tracks quickly and accurately, is polyphonic and is much cheaper than the Tripleplay. It's happiest with the single coil bridge pickup on my Strat but also works very well with the humbuckers on the Les Paul. I've got a friend who owns a Tripleplay and chooses to use the Jam Origin for most things which is how I found out about it. I think there is a new, cheaper Fishman unit on the way that is not wireless but for now I'm happy with Jam Origin. (and no, I have no connection with the company!) |
Tripleplay uses standard Windows/Mac USB MIDI driver. I'm using it every day with PC or Mac and and it works perfecly. No additional software required. Fishman soft is only usable to set up the pickup. Everything is stored in device so no add soft is required.
Jemusic wroteWhat other USB devices are you running. Maybe they are conflicting or interfering with the USB receiver in some way. Try turning your normal WiFi off perhaps and see what happens. USB plugged in: Tripleplay Studio 68 Faderport V2 wireless mouse I never tried turning off wifi but will give it a try. |
IanM5 wroteI can't solve your problem but I can empathise with it. Do you record with Jam Origin in Studio One without any problem? |
pawelhebda wroteTripleplay uses standard Windows/Mac USB MIDI driver. I'm using it every day with PC or Mac and and it works perfecly. No additional software required. Fishman soft is only usable to set up the pickup. Everything is stored in device so no add soft is required. Do you record with it in Studio One? It works fine if you use it to play live. |
gerardbechard wroteIanM5 wroteI can't solve your problem but I can empathise with it. Yes. the only problem is that it tends to highlight my clumsy and inaccurate fingers! It picks up all of those not-quite-muted strings and other stuff you don't notice with sustained sounds so I do have to do a bit of editing out of a few very short notes (they are very easy to spot after a while). |
gerardbechard wrotepawelhebda wroteTripleplay uses standard Windows/Mac USB MIDI driver. I'm using it every day with PC or Mac and and it works perfecly. No additional software required. Fishman soft is only usable to set up the pickup. Everything is stored in device so no add soft is required. I’m using Tripleplay only for recording. |
Users browsing this forum: No registered users and 31 guests
