I have an 8 bar loop on a MIDI instrument track. It plays fine by itself. If I duplicate it 3 or 4 times, it will sometimes play fine once or twice but eventually one or more of the duplicated loops' will just stop during playback. Sometimes loop 1 and 2 will play fine, then loop 3 will stop after a bar, then the 4th loop will begin again as it should after 7 bars of silence on Loop 3.
Please see attached screenshot, the volume just stops on the third loop where the timeline marker is at bar 18, but the other duplicated copies play properly. Using Studio One 4, Thanks!
by Tacman7 on Thu May 16, 2019 9:42 pm
I would zoom in and examine it closely.
Any weird stuff with notes right at the end?
Is it exactly one measure long?
That's usually what makes duplicating function erratically.
Probably others though.
Is there one really long note in there?
Hard to tell from the graphic.
Melodyne Studio - Nectar Impact LX25+
Where 'IS' Shitcreek? and
by markrobotham on Thu May 16, 2019 10:53 pm
I get this too sometimes, but what i`ve noticed is that on copied clips(keyboard shortcut D) it seems to move notes off the grid slightly (not quantized) once I re-quantize duplicate clips the problem goes away. Pretty sure this is a bug of some kind when copying clips. Not sure if this is the same issue but worth checking.
    Windows 10 Pro x64
    ASUS Z97-K Intel Core i7-4790K 4GHz 32 Gig Ram
    NVIDIA GeForce GTX1050 Ti
    Zoom UAC-8 Audio Interface
    Studio One 4.6.1 Pro
    Notion 6
    Sonar Platinum x64 Lifetime
[ YouTube ] [ Rasuresphere Omnisphere Library ] [ 10% Off Waves ]
by jordanbencharski on Fri May 17, 2019 10:01 am
Thanks for the replies. There are no odd notes in the sequence, and when playing any of them on their own they play back correctly. It is only when playing from the start of the song that usually the third sequence will drop after 1 bar, and then the 4th sequence, which is a straight duplicate of the third, comes back right on cue.
I did notice that when it does cut out, it is right at the spot where there is a sharp vertical spike in the gray graph over the track.
Thanks again.
by scottyo7 on Sat May 18, 2019 2:17 am
Try moving your whole 8 bar piece over to the right.
Don't start at bar 1 (the very beginning)... start on bar 2 or beyond.
I'm not sure if it was a bug (or maybe still is) but years ago we found that it's best to start on bar 2 or beyond.
Also after you move it all over to the 'right', grab the front edge of your first event and ensure the midi note data is not extending beyond bar 2 (that is into the end of bar 1) but is 'snapped' right to bar 2's beginning. ;)
If you've not already done so...
Please add your Signature & Gear Spec's to your Profile
Here.
ASUS Laptop, i7 3820QM; 16GB; 2 Samsung 840 SSD's; NVIDIA GTX 670MX; Win 8.1.
S1 Pro 4.6; EZD2 2.1.8. Behringer UMC404HD USB A/I.
Synths: Alchemy, Air Tech Music Suite.
Melodyne Studio 4.2.4. Ozone 5, (all 64bit).
Akai MPK249. 6 guitars. 2 Line 6 POD's & an E-bow.
Fluid Audio FX8 monitors; Dual 28" Displays. Rode NT1; SM58. Faderport;
-My Band: "2GUYZINABASEMENT"
-Just Me
by vanhaze on Sun May 19, 2019 3:23 am
jordanbencharski wroteThanks for the replies. There are no odd notes in the sequence, and when playing any of them on their own they play back correctly. It is only when playing from the start of the song that usually the third sequence will drop after 1 bar, and then the 4th sequence, which is a straight duplicate of the third, comes back right on cue.
Thanks again.
- Did you try, just for testing, another Instrument Plugin on that Instrument Track ?
- Could you maybe upload the S1 Songfile containing only the Instrument Track ?
Preferably with a S1 Instrument plugin inserted on it, instead of a thirdparty Instrument plugin.
Thx !
Macbook Retina 2015 | OSX Mojave (latest version) | Studio One Pro 4 (latest version) | UAD Apollo Twin Thunderbolt
Users browsing this forum: No registered users and 19 guests
