Is it possible to add more than one copyright field to a score? I have been working on an arrangement that contains a rather lengthy copyright that requires 3 lines of text to fit on the page. I can't simply press Shift+Enter like one would expect. When I try to add a 2nd copyright line, it deletes the first one... In the past, I have used the subtitle text field as a make-shift extra copyright line, but in this case I already have all the editable header/footer fields used up. Any ideas?
Not currently possible in Notion. Best bet is to add this via a PDF markup tool after printing the score to PDF..
willphillips2 wroteIs it possible to add more than one copyright field to a score? I have been working on an arrangement that contains a rather lengthy copyright that requires 3 lines of text to fit on the page. I can't simply press Shift+Enter like one would expect. When I try to add a 2nd copyright line, it deletes the first one... In the past, I have used the subtitle text field as a make-shift extra copyright line, but in this case I already have all the editable header/footer fields used up. Any ideas? Has it really been possible to change that in three years? Professional note editing program, but having trouble adding more text in copyright? "Deliver professional scores and polished performances." A bit of a joke. |
Hello,
It can be done. The trick is to add multiple copyright lines but NOT to check "Link to Metadata" for each When linked to metadata, I would guess there is a specific field value when converting to PDF that gets embedded in the document, otherwise it's just text on the page. That's probably why it only allows one line when that box is checked. |
